The cost of cheap (Free) materials
Home Forums Materials The cost of cheap (Free) materials
Viewing 25 posts - 1 through 25 (of 30 total)
  • #481483
    Martin Kyte
      @martinkyte99762
      Just a curious question really. It's me that is curious not the question. Do people find that it ends up as false economy working from scrapyard chuck outs, bin ends and other assorted size materials or is it really worth it. as opposed to close to size parent material of known composition. I frequently read of members here spending ages wrestling with large lumps of steel etc on smallish machines just carving out a blank to actually set to and machine a componant. Fair play to them and it may be heroic and all but are you spending too much time just cutting stuff up instead of actually making parts. With the internet and delivery times making correct sized material available almost next day is it really worth the hastle of reducing that peice of 2 inch by 1 inch bar down to 2 1/4" x 7/8" before you even start on the job let alone the time spent and the wear on sawblades/ milling cutters etc. I used to do all this but managed (largely) to kick the habit and I find I not only get more done but there is more of the enjoyable bits compared to the hard work.
      I'm sure a lot of it is just habit. I wonder what others think.
      regards Martin
      Edited By Martin Kyte on 22/06/2020 15:51:34
      Martin Kyte
        @martinkyte99762
        #481487
          Of course you get he experience which is 'priceless' blush
          #481488
          Clive Foster
            @clivefoster55965
            So true.
            I too need to kick the habit too, except for unfeasibly expensive large lumps for large jobs.
            I've got the equivalent of 3 or 4 filing cabinet drawers full of potentially useful bits. Which, truth to tell, only realistically come in handy a few times a year.
            Objectively I do the worst of both worlds. Buy for anything of respectably predictable size and keep all the crap I shall, most likely, never use.
            Old farts like me still remember when getting materials in small quantities at affordable, or even un-affordable prices was all but impossible. Access to works scrap bins being a prized privilege.
            I suppose the real answer is a modest collection of known offcuts in useful sizes. Once full the box is periodically refreshed when a "more useful than whats already in the box" size arrives with the least useful being binned. Instead of starting another box. So far I've tried twice resulting in dismal failures. I guess I'm a born pack-rat.
            #481489
              I just wish I was able to turn 2 x 1 bar into 2 1/4" x 7/8" like youwink 2
              I don't think it is worth it by the time you have faffed about trying to get a good finish, made more swarf than you really need to and worn out cutting tools there is not much of a saving.
              #481500
              Andrew Tinsley
                @andrewtinsley63637
                I quite often use scrap material, but only if it is about correct dimension and it machines OK. I can't really see a problem if you keep to those rules.
                Andrew.
                #481510
                Mark P.
                  @markp
                  Being time rich and monetary poor, I tend to use scrap bin materials.
                  Mark P.
                  #481511
                  Thor 🇳🇴
                    @thor
                    I do as Andrew. Most of the scrap I get for free from a milling, turing and welding shop and they tend to use S355 steel which machines OK. If I find the steel unsuitable I just return it to the skip. Some of the Cast Iron I use come from old disc brakes, it is fine grained and machines well. Certainely not as expensive as ordering online.
                    Thor
                    #481516
                      If my brother gets excess structural steel left over from a job, I am quite happy to use that steel.
                      I know of someone, recently, that paid a fiver for a metre length of 50mm x 3mm square steel tube. Not stolen!
                      I cut up an exercise bike recently, for the steel for a cutting and welding job. Should be OK as it was all welded together originally. More than adequate to make the support for a cutting table conversion of the band saw, for vertical operation. I expect I shall retain some round from it, too.
                      Anyone want the cast wheel? It is about 300mm diameter x 25mm at the rim. Still has a free-wheeling sprocket affixed to it.
                      I’ve often annealed steel shafts from scrap agricultural machinery – as long as the material machines OK. Stick a piece in the kiln, heated on E7 power and left to cool slowly.
                      You don’t think that Myford Boy (on you tube) buys in freshly produced aluminium for his casting projects, do you?
                      I have a stock of bought-in materials as well, of course.
                      I have machined down socket drive extension bars before now. And lots of other bits, too.
                      #481519
                      Rik Shaw
                        @rikshaw
                        My steel / iron stock of known flavours would probably weigh in at a ton or more but my first port of call for a new job is invariably the four large hoppers of scrap under one of the benches. I get a kick out of turning a rusty lump of tat into a useful tool or model part. For me it is all part of the pleasure !
                        Rik (eying up a sash weight for the pair of pistons I need) .
                        #481521
                        pgk pgk
                          @pgkpgk17461
                          I get bits of steel plate as scrap from a local steel framed agri building place via local scrappy – pick out what i want when he collects a trailer load and it's quite satisfying to turn rusty black stuff into parts. If I was commercial or in a rush it'd be a different matter. Other sized stuff gets bought from ebay, m machine etc depending on price.
                          pgk
                          #481524
                          Samsaranda
                            @samsaranda
                            I needed some material for a small solid flywheel, it was either going to be brass or stainless; my brother in law worked at a local engineering company before he retired and they used the full spectrum of stainless alloys from 316 to hastelloy and inconel. He said he would get me a bar end of 316 from one of the autos, he duly arrived with a 3 inch diameter blank about 3 inches in length, just what I needed. When I came to machine it I couldn’t touch it with a HSS tool I had to use carbide tooling and wind the speed up to remove any material, the finish I got was good. I think the reason that it was so hard to machine was because it was a bar end from an auto which obviously cuts at high speed generating a lot of heat subsequently work hardening the material adjacent to the cut area. The provenance of the bar end was not clear, it had no material ident, it could have been some other stainless alloy which might have been a difficult proposition for machining anyway. I think the moral is try to obtain materials with a known provenance, it can make life easier.
                            Dave W
                            #481530
                              Posted by not done it yet on 22/06/2020 17:26:26:
                              I
                              He certainly buys in the ZL12 Ingots
                              #481534
                              Martin Kyte
                                @martinkyte99762
                                Some interesting comments. I'm particularly bad at storing excess wood which is a dreadfull eater of space. It's all about balance really. I think we all suffer from old habits which suited our purpose once but as time change tend to hang around. As far as time rich, well yes I guess I am time rich as I'm semi-retired but I'm also cash rich too compared to years ago. However when I think ahead maybe I'm not so time rich as I might think. There certainly is 20 years less time left than 20 years ago. My mate died suddenly recently and he thought he was time rich too.
                                regards Martin
                                #481537
                                  Posted by JasonB on 22/06/2020 18:21:39:
                                  I
                                  Sorry, not picky proof without the “all’ which I should have inserted between the ‘for’ and ‘his’.
                                  #481542
                                  Mike Poole
                                    @mikepoole82104
                                    Nothing wrong with scrap and off cuts, but if you know what they are it helps, some are best left in the bin.
                                    #481552
                                    Oily Rag
                                      @oilyrag
                                      I have had some genuinely brilliant 'gifts' of scrap from friends and neighbours.
                                      One instance I had a knock on my door around tea time and opened it to find a near neighbour who is a builder with 3 10 ft (3mt) lengths of 25mm steel bar on his truck – "these just fell of a wagon on the by pass and I picked them up as they may be dangerous, thought you might be able to make use of them"
                                      Another time, I have a friend who worked for Rolls Royce and I needed some 614 Titanium so I asked him if he could get me some 'noggin ends' – after a time he came round and said it was too difficult to get but he gave me the address of the scrap yard that handled all RR scrap and suggested I went there asked to see a named guy and mention that I'd been given his name by a certain person at RR. I went to the yard and they threw open the place for me to hoover up whatever I wanted! I asked how much and they surprisingly said 'no cost' so I made a tea kitty donation in thanks – that's always appreciated.
                                      Since then I have had the run of their scrap! PB, Incalloy, Alum 2068 bar,EN 19, 24,32,33,40 – even some Copper Berylium off cuts. the later make excellent valve seats and valve guides.The great part about the scrapyard is they 'spark test' all the incoming scrap to sort it into grades for onward processing.
                                      #481557
                                      Ady1
                                        @ady1
                                        You learn a lot about different materials, but it can waste a lot of time concerning the learning curve
                                        The time lost has been largely made up with new skills using an angle grinder and welder which allow me to fabricate some pretty ridiculous projects
                                        It's about what floats your boat really
                                        Some guys just cut out the middle bit and buy a fully built model steam loco while other guys spend 6 years of their lives putting one together
                                        #481562
                                        Martin Kyte
                                          @martinkyte99762
                                          Posted by Ady1 on 22/06/2020 20:14:14:
                                          Totally agree with that. I have allways maintained that the primary product of the workshop is enjoyment. Some get that from making something out of nothing, others like building up the workshop and still others really just want to get the model done. All pockets all ages. I guess my point was, just now and again it's good to re-evaluate practices and habits so we don't get stuck in a groove. I'm sure I 'made do' long after I didn't have too.
                                          regards Martin
                                          #481575
                                          Mark Rand
                                            @markrand96270
                                            Picking stuff out of the skips at work can cause problems.
                                            That 1 metre length of 3" diameter CZ121 brass* very nearly crippled me. disgust
                                            *Marked on the bar, complete with purchase order number…
                                            #481578
                                            old mart
                                              @oldmart
                                              I made some super engine plates for a motorcycle back in the sixties with some very nice 1/4" aluminium plate from the scrapyard near where I worked. I have a hoard of metal under the benches at the museum, when the metal budget is zero, you learn to keep anything just in case.
                                              #481602
                                              Bob Stevenson
                                                @bobstevenson13909
                                                As a clock builder making clocks from scratch I need to work out the design of various parts and assemblies. This means that I more or less have to use materials from my collection of scrap. it's one thing buying new materials for the worked out design but while I'm getting to that point it can get very expensive, especially when bits get made a couple of times to get things right. If I was making published designs unchanged tghings might be different but there is not point (to me anyway) to make yet another example of John Wildings sleleton clock unchanged from all the others at any model engineering show…….
                                                But then, I have always made stuff from choice scrap and clock making is a rather expensive hobby. It's quite usual for the new materials for a nordinary clock project to cost about two hundred pounds. A couple of years back I met a chap at the Ally Pally show who told me that he had spent so much on the materials for clock build that he had never had the courage to start on it. I recently met another clock maker who complained that the brass and gold plating for his new clock build had cost over two thousand pounds…….Admittedly it will be a very nice and very expensively valued clock but, personally, I can't afford to do this.
                                                My first clock had suspension spring made from old feeler gauge, screws made from supermarket trolly dumped in Epping Forest, pendulum rod made from stainless coat hanger and other bits turned from an old ball valve rod…..even so it turned out to be an expensive clock!
                                                #481603
                                                magpie
                                                  @magpie
                                                  I agree with everything you have said there Bob. If I had to buy any of the brass for my fibre optic clock from the normal dealers it would never have got built. Every last bit of brass was from my local scrapyard, and some of it was in large lumps that would have cost a fortune. The only things new on the clock were the electrics.
                                                  Dek.
                                                  #481611
                                                  Nigel Graham 2
                                                    @nigelgraham2
                                                    What no-one seems to mention is the added machining time, i.e. electricity, that might be incurred, especially if you have to anneal that nice shiny come-on-handy near-ingot you found.
                                                    Or wasted solder and gas if what you thought was some sort of brass or gunmetal, was – but not the sort it appeared.
                                                    (Been there, done that… I learnt later it was almost certainly an aluminium-bronze, as tough as old boots to drill and impossible to silver solder properly.)
                                                    #481618
                                                    Bob Stevenson
                                                      @bobstevenson13909
                                                      Well maybe no one mentons it because that has not been their experience……..personally I have never expected to silver solder "aluminium bronze" satisfactorily so have never tried to.
                                                    Home Forums Materials Topics
