Hello Kevin, you are in a club then ask the boiler inspector or see if someone has the drawing with the information on it. As there are only 2 stays I'm assuming that these are longitudinal stays. Are they threaded or silver soldered in? Material is most likely to be phosphor bronze but may also be copper but check before you do anything.
Brian
Edited By Brian H on 27/11/2019 20:36:49
