O ring sizes?
O ring sizes?
Home Forums Materials O ring sizes?
  • #29962
    Vic
      @vic
      Vic
        @vic
        Do any of you know off hand how small a section O Rings are available? I’ve just ordered some 1mm ID 1mm cross section O rings but they may be a bit too big in cross section.
        #432692
        David George 1
          @davidgeorge1
          I believe that 0.5 mm section is the smallest size have a look on simply bearings web site.
          David
          #432696
          Vic
            @vic
            Pretty sure it was simply bearings I looked at, smallest was 1mm. I’ll check again.
            #432704
              Vic
                @vic
                The smallest standard size seems to be 1mm CS but I’ve found a specialist supplier that make miniature O rings. I’ve now found a supplier though that has O rings specifically for my needs. Not sure what size they actually are so I’m going to see if the ones I’ve ordered elsewhere fit first.
                #432731
                S.D.L.
                  @s-d-l
                  Seen down to 0.1mm cross section x 0.3mm OD
                  Steve
                  Edited By S.D.L. on 10/10/2019 21:19:24
                  #432736
                  Grindstone Cowboy
                    @grindstonecowboy
                    You could try Polymax
                    #432737
                    Vic
                      @vic
                      Thanks for the link GC. smiley I’m sure they go down small enough and the prices look good although I’ve not checked the postage.
                    Home Forums Materials Topics
