Hi Nick,
Here we go again…………
Don't understand the "true brazing" bit! Brazing is a process of joining metal and its success depends on capillary flow. Brazing has nothing to do with the filler metal used! You can braze with copper, silver, gold, palladium, and nickel alloys
You can use sifbronze on your boiler, you just need heating equipment that will give you the extra 250 deg C to melt it compared to using a silver bearing brazing alloy.
You will probably need an oxy acetylene torch working alongside your propane torch.
You will probably need to enter contracts, bottle hire agreements, increased storage issues to satisfy your gas supplier.
But yes, it can be used. It's just easier with a silver brazing alloy. OK it's more expensive but easier. You pay your money and take your choice.
UNDER NO CIRCUMSTANCES USE A SILBRALLOY TYPE MATERIAL IN A COAL FIRED BOILER. IT'S CHEAP AND WILL PRODUCE STRONG JOINTS BETWEEN COPPER COMPONENTS WITHOUT THE NEED FOR A SEPARATE FLUX.. SULPHUR FROM THE COAL WILL RENDER THE JOINT POROUS AND IT WILL FAIL.
Spelter is an old word used to refer to a brazing alloy. Who knows what "easy running strip" is? Probably a name adopted on a shop floor in the antiquities of time!
As for the cheap stuff on your link – why not ask the supplier? Let the buyer beware!
For more information see my book based on 50 years experience in the brazing business. Or talk to CuP Alloys. They will tell you.
Keith
