Unbendable casting!
Unbendable casting!
Home Forums Materials Unbendable casting!
  • #29872
    AJW
      @ajw
      AJW
        @ajw
        Cracking on with my Centaur build I have now got to the cast gunmetal head casting.
        I noticed one of the rocker lugs was out of line and would not be recovered in machining.
        So I had a bright idea of heating the affected area with my propane/oxygen torch so I could ‘bend it straight’
        It just cracked and broke off! Well happy.
        I take it cast gunmetal is quite hard and in annealable?
        You live and learn.
        Alan
        #383123
          Condolences, Alan
          My guess is that you de-zincified it by using the torch.
          https://en.m.wikipedia.org/wiki/Gunmetal
          http://www.airproducts.com/Industries/Metals/ask-the-experts-metals/heat-treating/dezincificatiion-apply-thermal-processing-brass.aspx
          Edited By Michael Gilligan on 30/11/2018 21:56:07
          Edited By Michael Gilligan on 30/11/2018 21:59:16
          #383137
            I find GM castings are very soft and easily bent if you are careless with your clamping or have a major tool dig in. Probably would have been better to tweak it cold. Only last week I had some GM bearing s that had cupped a bit and just gave then a good squeeze in teh vice to flatten them out before starting to machine, these were 1" x 1/2" section.
            On the bright side it is easier to silver solder the offending part back on than it would be with an iron casting.
            #383149
            MichaelR
              @michaelr
              Sorry to hear that, I had the same problem on my Centaur cylinder head I got it back inline by bending cold, as Jason says you should be able to silver solder the arm back on.
              #383161
              AJW
                @ajw
                In hindsight I should have checked it over better upon receipt when I would have spotted it and had a word with the supplier or sent it back!
                I get the feeling that the bend was caused as it came out of the mould, dropped?
                I’m not sure about silver soldering it back, there is a crack further down the arm meaning I would have to remove it first, meaning 2 breaks in the same section. On top of this the arm, which is webbed, still has a bend in it!
                Alan
                #383164
                Former Member
                  @formermember19781
                  #383193
                  Nigel Bennett
                    @nigelbennett69913
                    Many copper alloys are known as "hot short". This means that they don't take kindly to being battered when hot. I found this out myself once when trying to form a head on a piece of bronze bar. It simply turned to mush under my hammer! Hence forming copper alloys is generally best when they're cold.
                  Home Forums Materials Topics
