Good evening folks, would anyone know of a source for just one or two 13/32" taper pins please. I might as well go for a 6" one and cut according to how much I need to ream out.
I've spotted an ebay source, but they only do bags of 5.
I've checked the links in the previous threads on here to no avail.
It's for a clapper box pivot pin on a recently acquired Boxford shaper.
It's currently fitted with a 3/8 one, which is at the limit of its adjustment.
I've borrowed a No.7 reamer from a friend, but not about to try using it unless I can source a pin first.
If all else fails, I guess I could make one, as I have the reamer to clock from, to set the taper on the lathe. Any thoughts on material? EN8??
Cheers
Bill
