Gaskets
Gaskets
Home Forums Materials Gaskets
  • #256606
    Mike Brett
      @mikebrett89695
      Hi
      I am trying to cut some small intricate gaskets for a steam engine. The material I have at present I got of E-Bay , it is of a bluish colour about 0.50 mm thick.
      Trouble is it is so fragile , trying to put the gasket over studs and it just falls apart. Is there a stronger material brand on the market that anyone could recommend.
      Cheers Mike
      Mike Brett
        @mikebrett89695
        cutting gaskets
        #256615
          Lay gasket on face and then fit the studs? Standard A4 paper is about 0.1mm, so about the thickness of 5 sheets of paper?
          I've no suggestions for an alternative. Try another internet source might be a possibility – epay quality is not always good quality.
          What size are we talking here? Small, for me, is less than 50mm
          #256617
          Mike Brett
            @mikebrett89695
            Good idea about fitting gasket then studs, unfortunately I have already fitted studs with loctite . Gasket is 8 mm wide with 4 mm holes for studs, not much either side of studs.
            #256623
            DMB
              @dmb
              What about clamping the already drilled steam chest to a block of wood with gasket sandwiched between and poke drill through?
              Just a thought.
              duncan webster 1
                @duncanwebster1
                Are you trying to punch holes for the studs, or just fit a gasket with holes already in it?
                #256638
                John Hinkley
                  @johnhinkley26699
                  First, let me say that I know diddly squat about steam engines, but if I had to do what you are trying to acheive, I think I would lightly fix the gasket to whatever goes over the studs and fit it that way. (Kind of like a cylinder head sliding over the studs in an IC engine block. ) By definition, the fitting, valve chest cover or whatever, doesn't have any protuberences to get in the way. Or have I got hold of the wrong end of the stick?
                  Alternatively, use a thicker material or gasket goo in a tube.
                  Good luck.
                    One thought – are the stud ends at the same dimensions as at the root
                    ie, exact same pattern.
                    Another is to make the gasket as a larger sheet and trim to size after fixing.
                    Edited By not done it yet on 18/09/2016 18:10:59
                    #256659
                    Mike Brett
                      @mikebrett89695
                      Many thanks for all your replies. I had already drilled the gasket, it was getting it over the studs that was the problem. The best solution I can see from the replies is to fit as a complete sheet and cut to size after, why did I not think of that. If that fails I have seen gasket material made of nitril, not sure if this is steam proof though.
                      #256662
                        Liquid gasket works for me. Teflon baking sheet works for others
                        You say that you drilled the stud holes in teh gasket? this may well leave a ragged edge which won't help with tearing, they are better punched out either with a Wad (hollow) punch or a punch and die (4mm peg and 4mm hole in die)
                        Edited By JasonB on 18/09/2016 19:39:10
                        #256736
                        Howi
                          @howi
                          Teflon baking sheets as has been suggested, silicone sealer etc. For cutting stud holes I would suggest getting hold of a radio telescopic aerial, cut the end off and hey ho you have a series of hole cutters, just sharpen the inside of the base of each tube and a simple twisting action cuts a perfect hole with no tearing as you would with a drill.
                          #256739
                            Gasket holes shouldn't be a tight fit to the studs, you need to be sure they don't get damaged edges or crinkles.
                            #256744
                              In addition to Neil's comment, the studs can be waisted slightly. Not an easy solution if they are already permanently affixed. Just depends on the strength of the material and the designed working forces. The threads are likely the limiting factor, rather than the cross sectional area?
                              #256766
                              Ian S C
                                @iansc
                                To cut the holes, lay the gasket paper on the part with the drilled holes, find one of the holes through the paper then using a ball bearing a bit bigger than the hole, put this on the hole and give it a whack, first hole, put a peg in the hole through the paper, and do the same for the next hole, put in another peg, carry on and do the rest, then tap around the edge of the casting or what ever, and the sharp edge will cut the gasket. Some bit might need cutting, but often the whole gasket can be made this way.
                                Ian S C
                                #256769
                                Trevorh
                                  @trevorh
                                  Try using a Paper Drill Bit – gives a perfect hole in most soft materials
                                  google paper drill bits
                                  cheers
                                  Trevor
                                  #256775
                                  Lambton
                                    @lambton
                                    Mike,
                                    Try
                                    http://www.stationaryengineparts.com
                                    They sell plain gasket paper as follows.
                                    "Suitable for mineral oils, hydrocarbons and cold water not suitable for acids and steam. Maximum temperature 120'C Available in 0.25mm, 0.5mm, 0.8mm and 1mm thick all from 1 metre wide rolls".
                                    For cutting holes I use a revolving leather punch e.g. Clarke CHT489 about £8 from Machine Mart. It has punches 2,2.5,3,3.5,4 & 4.5 mm diameter. For larger hole I use wad punches.
                                    I hope this is of help.
                                    #256777
                                    duncan webster 1
                                      @duncanwebster1
                                      Posted by JasonB on 18/09/2016 19:36:16:
                                      +1 for punch and die, they don't need to be hardened, in your case make die cylindrical, 7mm OD, 4mm hole, hold it in drilling vice, grind the non cutting end of a 4mm drill so it has sharp corners, then fit the gasket to the cover and use it to position the holes, poking the punch through the holes in the cover
                                      Edited By duncan webster on 19/09/2016 11:55:18
                                      #256807
                                      Brian Wood
                                        @brianwood45127
                                        Mike,
                                        ​My father made a cylinder head gasket for a lawn mower engine from thick brown wrapping paper, using the sharp edges of the metal to cut the shape by tapping round with a small ball pein hammer. Bolting holes were cut with the ball end of the hammer pushed into the gasket and the plain end tapped with a second hammer. A smear of grease both sides completed the job before bolting up.
                                        ​He said it was a common dodge used by him and his biking friends as a field repair; the lawn mower engine ran for years like that afterwards.
                                        ​I have since made many such gaskets for other applications, the last being from a paperback book cover found in the back of our Landrover for a roadside gasket repair to the CAV diesel fuel pump. It was still doing good service when we sold the vehicle 4 years later.
                                        Brian
                                        #256829
                                        duncan webster 1
                                          @duncanwebster1
                                          Is this **LINK**
                                          the ptfe sheet people are referring to?
                                          #256842
                                          Tim Stevens
                                            @timstevens64731
                                            Surely the right name for a firm selling gasket paper to model engineers, is 'Stationary stationery' ?
                                            Tim
                                            #256847
                                            John Stevenson 1
                                              @johnstevenson1
                                              Know anyone who has a laser ? A lot of maker types have them.
                                              Brilliant at gaskets.
                                              The hole in the middle is 1mm, the hole towards the outer edge as is the annular slot are both 1/2mm.
                                              14 seconds to cut this and can cut as many as I want with same accuracy.
                                              #256853
                                                Posted by John Stevenson on 19/09/2016 19:21:08:
                                                Just make sure you declare it to the Juges, if you enter the engine into competition.
                                                devil MichaelG.
                                              Home Forums Materials Topics
