4mm BMS plate
4mm BMS plate
Home Forums Materials 4mm BMS plate
  • #29565
    Peter Simpson 1
      @petersimpson1
      Peter Simpson 1
        @petersimpson1
        I,m thinking of remaking my "Speedy" frames. I would like to use 4mm Bright Mild Steel. After searching the internet I cannot find a supplier. Does any body know of a supplier out there ?
        Thanks Peter
        #219206
        duncan webster 1
          @duncanwebster1
          I wouldn't even consider using bright plate, it's full of stress caused by the cold working, and is likely to distort as soon as you start shaping it. Use black, which I would get from a local fabricator for a contribution to the tea fund. Even better get it laser cut.
          #219212
            Lazermasters will cut a couple of rectangles of 4mm or you could get them to do all the cutting. I'm 95% sure their's is pickled & oiled so should not have the stresses of bright but will not have the scale of black
            Edit they do S275 which is hot rolled
            Edited By JasonB on 03/01/2016 17:54:19
            #219215
            duncan webster 1
              @duncanwebster1
              What's wrong with scale? It means you don't need marking out fluids, and the paint sticks better. It doesn't flake off, it's only very thin.
              #219217
                It also blunts your tools, I always chuck any black stuff in acid before I work on it, the scale soon drops off to leave a nice mat grey finish that you can mark out on.
              Home Forums Materials Topics
