Soft Faced Hammer
Soft Faced Hammer
Home Forums Materials Soft Faced Hammer
Viewing 25 posts - 1 through 25 (of 28 total)
  • #71881
    Dave Tointon
      @davetointon92281
      G’Day Gentlemen,
      What is the best material for making soft faced hammer replacable faces. I am thinking nylon or some other plastic stuff.
      Thank You and Regards
      Dave Tointon
      Dave Tointon
        @davetointon92281
        #71883
        Gray62
          @gray62
          It all depends on what you are hitting with the ommer and what results you intend to achieve.
          My ‘Soft’ faces have a variety of heads, all produced in the workshop, which vay from lead (very soft), thru copper, brass, Delrin, Nylon, etc.
          It all depends on what you want your ommer to achieve
          A little more info on what you are using the ommer for will assist in advising suitable materiels.
          regards
          CB
          #71885
          Dave Tointon
            @davetointon92281
            G’Day Coalburner,
            The normal type of thing, giving say a casting a whack in the 4 jaw chuck to set it up, loosen a camlock chuck on the lathe. The face needs to be soft enough not to mark mild steel but robust enough to tolerate some abuse.
            Bogstandard
              @bogstandard
              Dave,
              Not really replaceable faces.
              For many years now I have used nothing but a lead hammer, held by the head, not the handle. They are made from the very soft lead flashing used for roofing.
              I find that anything else tends to ‘bruise’ soft materials, even nylon and some rubbers will damage soft surfaces. Plus the ‘dead blow’ effect is perfect for setting any material down onto parallels.
              Just remelt and recast in a simple mould when the ends of the head look like mushrooms.
              #71891
              ady
                @ady
                A bit of beachcombing can produce some big lumps of very hard plastic which have various uses in the fishing and boat industry.
                They can make very handy drifts and hammers when cut up, machine easily, and don’t even seem to bother aluminium.
                #71893
                Richard Parsons
                  @richardparsons61721
                  Get your self a Raw Hide mallet. You can make them by soaking the rawhide and rolling it up into mallet head. Clamp it with a few hose clips and some nails. Then let it dry.
                  #71900
                  Dave Tointon
                    @davetointon92281
                    Thank You gentlemen. As always, a wealth of ideas and info. I think perhaps I’ll go for a lead job.
                    Ian S C
                      @iansc
                      One of the best things I’v got for thumping things is a bronze pin from an Eaton dif. Next is an aluminium alloy push rod out of a Pratt & Whitney R 1830 from a DC 3, back in the 60’s when I was doing my apprenticeship, the engines were being changed over to steel push rods, so we all got one. Ian S C
                      #71928
                        @mike89748
                        Lead doesn’t have to be very soft. If you want something a bit harder than pure lead, try melted down and cast shotgun shot, which contains a small percentage of antimony. I believe lead wheel balancing weights are even harder.
                        #71941
                        Sub Mandrel
                          @submandrel
                          Use your head…
                          I use either a big rubber mallet, a small nylon faced hammer or a bit of wood, alone or with a hammer.
                          The Aged P. has a very nice copper-faced Thor hammer.
                          NJH
                            @njh
                            Hi Guys
                            My “Persuaders” are :- Thor No. 2 – Copper one end, hide the other. I bought it 40+ years ago and I use this one the most. Nowhere near needing a new insert at either end. Rubber headed mallet and a Boxwood mallet with a cane handle – occasional use, mostly around the house on D.I.Y. projects or, in the case of the boxwod one, thin sheet metal.
                            In my experience, in the workshop, a light tap with a heavyish mallet is to be prefered to belting the daylights out with a light one! ( Although on D.I.Y projects which go wrong there is something to be said for the satisfaction gained through letting off a little steam!)
                            Norman
                            #71945
                            Gordon W
                              @gordonw
                              Don’t use a hide mallet, they break up, get bits all over the place. My lump of choice is a length of brass bar, with a key -way down , was once a prop shaft for a boat, no use for anything else now. Have toyed with the idea of making a lump of lead, will do one day. The point of this is that you don’t really need a hammer, just something suitably heavy.
                              #209028
                              Chris Denton
                                @chrisdenton53037
                                I know it's an old thread, but what is the rubber material used on the cheap rubber mallets?
                                Would it be suitable for drilling and taping a thread to insert M12 studding?
                                #209030
                                Johnboy25
                                  @johnboy25
                                  Rubber? 😋
                                  #209032
                                  Johnboy25
                                    @johnboy25
                                    Well I'm still laughing – must be the Friday night bottle of wine 😜
                                    Edited By Johnboy25 on 23/10/2015 22:05:23
                                    #209033
                                    Johnboy25
                                      @johnboy25
                                      Sorry Chris 😳
                                      #209050
                                      Chris Denton
                                        @chrisdenton53037
                                        It seems more plasticky than rubber though?
                                        #209074
                                          I doubt it would hold for long. They have a very coarse male thread and take the impact force on a shoulder as plastic just isn't tough enough to take blows. When it fails you might recover it by making the end of your screw flat, the bottom of the hole flat, and fixing it with a rubbery glue.
                                          #209093
                                          Richard Marks
                                            @richardmarks80868
                                            Does anybody have any experience regarding the removal of the copper head in a Thor copper and rawhide hammer, the copper end is getting short so if I can remove it a new one can be fitted bringing it back to life.
                                            Many Thanks
                                            #209097
                                            Chris Denton
                                              @chrisdenton53037
                                              What it's for is I'm making my own hammer with replaceable heads in a variety of materials.
                                              It's probably easiest to just buy a cheap rubber mallet and use the material from that to make the insert. I assume it'll machine ok if it threads ok? The studding that I'd put into it would be glued anyway so it should be ok?
                                              #209122
                                                Posted by Richard Marks on 24/10/2015 13:05:08:
                                                Many Thanks
                                                If there's enough left, clamp the copper up really hard in the vice and pull the handle round.
                                                #209127
                                                Chris Gunn
                                                  @chrisgunn36534
                                                  Richard, I guess your copper head hammer has mushroomed over so you cannot grip it and twist it out. My method is to smooth the face off, and mark it out and drill a series of 1/8" holes at 1/4" pitch, then open them out to 1/4", and then chimble the bits out.
                                                  Chris Gunn
                                                  #209132
                                                  Alex Collins
                                                    @alexcollins55045
                                                    Drill the copper for M6 or M8. Tap It ( yes I know copper is far from easy to tap ) And screw it out using a bolt.
                                                    If that fails keep drilling until you can break it up.​
                                                    #209138
                                                    Richard Marks
                                                      @richardmarks80868
                                                      Many thanks for your replies, tried the vice thing but felt the handle might break before it twists, anybody know the thread size that holds it in, thought maybe drill close to the size then try twisting again.
                                                    Home Forums Materials Topics
