I have recently bought a Classic mini 1979 vintage. I should be asking on a mini forum, but getting technical – How do they do this ?
I am guessing that the car has been "Tweaked" and that the gearbox / final drive has been swapped out at some stage. Not a problem but the speedo reads !00Kph when the car has a GPS speed of 80 Kph.
Following he net, the speedo drive gear should have 16 teeth, but there are also 17 and 18 tooth varieties.
So it could be that I have the wrong gear or wrong speedo. However, moving on, How could you fit different sized gears without changing their centres.
this the typical sort of thing Speedo drive gear
Bob
