Posted by Stephen Follows on 05/06/2023 18:02:04:
Done it again…
(0.003"
The horrible automatic smileys are a feature. When computers only had text screens, no graphics, it was the height of sophistication for folk to make emoticons by concatenating characters. Loads of possibilities such as:
- smile : – )
- sad : – (
- confused :-J
When everybody got graphics screens it became fashionable for software to show off by automatically converting text emoticons into their graphical equivalents. This forum does it, which is very unfortunate because engineers often use symbols like " that have been stolen by the emoticon crew. The text combination " ) is a wink. I stopped " ) being converted into a winky in this post by inserting an extra space. Type (0.003" )
Back to run-out, my guess is that the new collet chuck is a close fit to the register and either the register is worn, or the matching part of the chuck isn't quite true. So when the nuts are tightened the register pushes the chuck out of alignment. If a tight fit, I suggest opening up the chuck slightly to create room for it to move relative to the register. Then centring by tapping as per Jason's advice will work.
Registers wear a little every time they're used. How good or bad they are depends on the history of the lathe and the years are often unkind. A lathe that's spent its life constantly switching chucks is unlikely to have as good a register as one owned by a gentle hobbyist who did everything with the same 4-jaw.
