Your error over 25 mm or 1" will be so small as not worth worrying about.
Your mag chuck may well be distorting the work if it is thin. This is what I was hinting at in my earlier post. Old feeler gauges make good packing when placing work onto the Mag chuck, before engaging the magnets.
The Mag chuck should from time to time be reground, but be sure all other sources of error are eliminated first.
Wear very often takes place in the centre of the table. It is where most people tend to place the work. Operators of Surface grinders will often place parts all over the table to minimize wear and save on table regrinds.
Strips of thick rubber with an aluminium backed edge. Rather like a Tenon saw, make good cleaning aids for the table. To remove dust and coolant, but nothing beats the palm of your hand afterwards.
T'other Gray,
Edited By Graham Meek on 03/06/2023 11:29:48
