Don't forget that IF you decide to fit / make a longer feedscrew, the thread will be Leaft Hand..
As already said, mountingttb the tooling on the outer face of the 4 way toolpost will increase the diametr capacity.
But be aware that of the power of the machine.. Increasing the diameter of the workpiece means that the cutting forces require a matching increase of torque, which might overtax the motor and / or driveline.
Because of the larger diameter, for the same surface speed, the spindle speed, and motor speed will be reduced.
The lower motor, and cooling fan, speed will mean less flow of cooling air for the motor, so overheating / failure becolmes a possibility!
In the words of a very old radio programme
"Don't force it Phoebe"!
Howard (Wireless keyboard sometimes cam't cope with my low typinbg speeds )
Edited By Howard Lewis on 02/05/2023 14:51:56
Edited By Howard Lewis on 02/05/2023 14:52:30
