Sometimes cheaper than buying a sheet of metal yourself.
Size does nor give a good indication of cost. Machine time and the number of holes is what costs so just cutting a rectangular A4 sheet would be a lot less than a complex part that would fit within the same overall size piece of metal. they are unlikely to be cutting from imperial sheet these days
The link I posted has quick pricing of basic shapes on line so have a try, you can send files of more detailed items for a quote. They are happy to do one off jobs and have run adverts in the mag in the past so are used to dealing with MEs
EDIT, just tried it out to show it is not size that matters, 300x200x6 solid is £17 same sheet with a 250 x 150 cut out is almost double at £31
Edited By JasonB on 10/02/2023 10:34:20
