I think Edward just shows a parallel (height) keyway and the gib head key when fitted just gets a fraction taller over the last 1/3rd of its length so it tightens up when driven home, thats how I usually do mine rather than make a tapered bush to get a tapered keyway and matching tapered key.
Provided you have the right bush which is a good fit in the bore and the correct shims to go with your key then driving the broach right through until all the shims are used will give you the correct depth of keyway. I'm assuming you are broaching as I saw you asking about for one a week or two ago.
Although Gib head keys can be bought ready made I use rectangular keysteel, mill most of the profile and then finish fit with files and engineers blue. It helps to leave the keysteel full length then you have more to get hold of to remove the key while test fitting
