Valve handwheels
Valve handwheels
Home Forums Traction engines Valve handwheels
  • #63480
    Bernard Laycock
      @bernardlaycock66604
      I am building the 11/2″ scale Allchin and am trying to fabricate the valve handwheels in steel. They are a very unusual design, but I am sure many model engineers have succeeded, even though the construction manual is lacking any detail of this task. I wonder if any member who has managed what to me is an impossible task. I wanted to include a photo of the prototype and a photo copy of the drawing, but I can’t work out out to do this. Any information would be much appreciated. Bernard
      Bernard Laycock
        How to make
        #63481
          I think I would turn the handwheel including a flat disc all the way around the outside and then file that disc away to leave the four protruding grips.
          Other option would be again to turn the wheel and solder four lengths of flat strip to the rim which could then be cut back to length and filed to profile.
          Jason
          #63494
          Jeff Dayman
            @jeffdayman43397
            Any chance of a pic of what shape you’re trying to make Bernard? I may have some ideas on how-to (or know where to get some similar commercial ones)
            Thanks JD
            #63499
            Bernard Laycock
              I could post a photo and a drawing, but I can’t figure out how to insert these into my post.
              #63565
                Bernard, the easiest way is to go to the headings along the top of the homepage and click on Albums. This will then give you the option of creating an album where you can upload photos and scans from your computer.
                When posting click on the “insert image” icon along the top of the reply window and select the photo from your album. Something like this should then appear.
                As I said its all turning then either solder the 4 tabs on as overlength strips or leave a disc all round the outside to be cut away in much the same way you would with a spoked handwheel except the “spokes” are outside the rim.
                J
                #63567
                Stewart Hart
                  @stewarthart90345
                  This is the handle I made for my loco
                  [IMG]http://i431.photobucket.com/albums/qq32/sbwhart/Mabel%20Valve%20Gear/100_2041.jpg[/IMG]
                  and this is how I made it
                  [IMG]http://i431.photobucket.com/albums/qq32/sbwhart/Mabel%20Valve%20Gear/100_2031.jpg[/IMG]
                  Hope this helps
                  Stew
                  #63583
                  GoCreate
                    @gocreate
                    Hi Bernard
                    Although in 3″ scale, I made the valve handles as Jason’s first description, that is, turning to shape and including a flat ring on the outside, then filing away the flat ring to leave the 4 tabs.
                    Nigel
                    #83001
                    Bernard Laycock 1
                      @bernardlaycock1
                      Hi Stew
                      I’m sorry to say that I missed your post of 04/02/2011 about the making of the Allchin valve handle and I find they have now been deleted. Is there any chance you could repeat them for me? I would be grateful.
                      Bernard
                      #83195
                      Bernard Laycock 1
                        @bernardlaycock1
                        Hi Jason
                        Thanks for the reminder about your previous post. For some reason I lost track of this topic and appreciate the reminder
                        Bernard
                      Home Forums Traction engines Topics
