Hi Ian
Thanks do much for your post, I had not thought that the resin could peel off but now it seems logical that it might. I have plenty Isoflex liquid rubber and primmer left over from fitting the rubber tyres so I will probably use that. Another person did mention Isoflex.
Not sure that hot dip galvanising will be good for getting a flat and pristine paint finish on the external surfaces. Maybe a spray galvanising or something.
As a matter of interest ;I collected my profiles and plate material today, so this week end I make a start, first job is to radius the former. I supplied a dxf file which the profile company had no problems using, I had imagined that I would need to do alot of work cleaning up the former edges but they are very smooth and even , I hardly need to do anything, A lot different from what I remember when I was working in a workshop 30 years ago.
Thanks again
Nigel
