Thanks guys, I like the idea of the Nelson eccentric clamp but don’t want it to get too bulky and obtrusive.
Depending on how much space is available I could consider a tapered collet type setup although as Jason says, once it’s setup it will stay setup so the simple grubscrew changed for a pin later sounds the simplist.
What do you think about the ‘end on’ grubscrew in the gears/shafts as any adjustments would be made at the cam end?
Alan
