Valve Springs
Valve Springs
Home Forums I/C Engines Valve Springs
  • #108577
    Sub Mandrel
      @submandrel
      For my single cylinder 4-stroke, I'm copying the valve arrangement for ETW's Seal with minor tweaks. The valve area is the same – about 9/32" diameter valves and a 1/4" diameter passage. I've now made valve guides, valves, tappets and tappet guides, I need to sort out springs.
      I have all but the last one or two installments of the construction series for Seal – but I can't see anywhere where he gives a specification for the valve springs.
      Can anyone suggest what sort of spring load will be needed on such small valves – I have no idea if it should be a couple of grams or a couple of ounces!
      Sub Mandrel
        @submandrel
        #108593
        Roderick Jenkins
          @roderickjenkins93242
          Neil,
          You should be able to work out the valve acceleration from the cam profile and max engine speed. From this, together with the weight of the valve components you can work out the force required to counteract the kinetic energy of the valve gear and keep it in contact the cam.
          So much for the theory. In practise you can compare it with other similar designs. What is the capacity of your single? As a start, the 10cc Matador OHV uses a 4 turns of 22 swg 1/4" OD and 3/8" long. My own design 10cc side valve, which a has a more aggresive cam than the Matador uses 5 turns of 22swg with an ID of 1/4" and 0.6" long. Both of these seem to work fine in my experience up to 10,000 rpm.
          I can also let you have copies of the missing instalments if you wish.
          cheers,
          Rod
          Edited By Roderick Jenkins on 13/01/2013 20:19:06
          #108600
          Sub Mandrel
            @submandrel
            Thanks Rod,
            My last installment is Vol. 96 No. 2405 26 June 1947, which covers the carburettor. I'll pm you my email address if you are able to scan them for me.
            My engine will be about 3.5CC. the springs I have are 1/4" OD about 22 swg like the matador ones, but are about 3/4" long and more like 10 turns.
            Set to what would be the likely position (with no camshaft yet I can't be precise) the inlet requires 23lbs and the exhaust 2 1/lbs! IThis seems way more than is needed. My guess is 8oz would be OK, but that is just a guess, no more.
            Have you a rough idea how much force it takes to fully open the valves on one of your engines? If I work to about 1/3rd to 1/2 of that, i don't think I'd be far wrong.
            Many thanks
            Roderick Jenkins
              A crude measurement with a spring balance shows about 3 1/2 lbs to open the Matador valves.
              Looking at my Mastiff book, Len Mason used 22swg 1/2" long, 6.5 turns and 7/32" ID. This for a four cylinder 24cc . I've got the drawing for ETW's Kinglet: no mention of valves springs on that either- in fact the drawing leaves quite a lot to the imagination.
              cheers,
              Rod
              #108700
              Sub Mandrel
                @submandrel
                Gosh! Seems my random springs aren't far off. I can trim a spring experimentally to get about 1lb – I have four.
                Thanks for going to the trouble to help.
                Edited By Stub Mandrel on 14/01/2013 20:24:43
                #108748
                Ian S C
                  @iansc
                  Had an idea it might help, so I looked at Edgar T. Westbury's book "Model Petrol Engines", but there is no mention of the specs for valve springs on any of the engines, Ooh well its a nice wee book, does'nt tell too much about building, but it gives some ideas. Ian S C
                  #108799
                  Sub Mandrel
                    @submandrel
                    Looks like even the great E.T.W. had a blind spot
                    Roderick Jenkins
                      I've been whiling away the progression of a never ending cold by reading my newly acquired ME backnumbers. In April 1945 ETW tells us that the springs for his 15cc Kiwi are: 18SWG, 5/16" ID, 6 coils in 3/4".  He gives the impression that these were just a best guess but they seem to work.  I'm a bit surprised because he usually got Dennis Chaddock to do hisdifficult sums.
                      Rod
                      Edited By Roderick Jenkins on 16/01/2013 22:10:23
                      #108973
                      Francois Meunier
                        @francoismeunier96697
                        ETW, redesigned and republished 20 years later (24 NOVEMBER 1960 issue, p. 635) his Kiwi engine, with weaker valve springs !
                        quote
                        "I am often severely rapped by readers for neglecting to give details of valve springs, but it is difficult to specify essential dimensions, because ultimate strength and durability depend on several factors, including not only the quality and temper of the spring steel, but also the pre-stressing of the material in manufacture. For the best results, some experiment is called for; the springs which have been found satrsfactory are 3/4 in. free length, 5/16 in. outside diameter, by 20 s.w.g., with six complete turns, not including the flattened end turns." ME, 123, p. 635, (issue 3098, 24 Nov. 1960).
                        I recently did a 10 cc engine (video in my album) and was surprised by the raise in performance with the progressive increase in stiffness of the springs, about 2,2 kg to open the valve now.
                        Cheers
                        https://picasaweb.google.com/113249908069844921550
                        Edited By gedeon spilett on 17/01/2013 08:22:48
                        #108983
                        MICHAEL WILLIAMS
                          @michaelwilliams41215
                          (1)
                          *I've been whiling away the progression of a never ending cold by reading my newly acquired ME backnumbers. In April 1945 ETW tells us that the springs for his 15cc Kiwi are: 18SWG, 5/16" ID, 6 coils in 3/4". He gives the impression that these were just a best guess but they seem to work. I'm a bit surprised because he usually got Dennis Chaddock to do hisdifficult sums.*
                          A surprisingly large number of older people at the place that I was trained and worked years ago knew Westbury well and some even counted him as a personal friend . They had come to know him in three separate ways :
                          Through his collaboration and lifelong friendship with Whittle .
                          Via studies at Cranwell .
                          Via Model Engineering .
                          Whittle was a frequent visitor to my workplace and these visits continued into my time though sadly I never met him . He apparently had great respect for Westbury and often talked happily about his early jet engine days and the help and support that he got from him .
                          In their earliest days they had built and flown ic engine powered model aircraft where every single part was designed or made by one or other of them .
                          Whittle was well trained as an Artificer and had I believe a Higher Technical Certificate – not a bad qualifcation to have achieved pre war .
                          Those people that knew Westbury described him as quiet and reserved in his ways but with an immense wealth of technical and historical knowledge .
                          I never met Westbury but I did meet Chaddock several times . I would say that as an all round engineer Westbury outclassed Chaddock considerably .
                          (2) I've never liked the term Great Expert as used so freely in the Model Engineering world . In truth many of the much praised regular contributors to ME have been barely competent and some at least have been complete idiots .
                          There have been some excellent regular contributors – Westbury , Duplex and a few others over the years . What makes me sad though is that many of the real experts in Model Engineering don't often write articles and are quite unknown to the general public .
                          One of these unknown experts was the late Eric Grifiths of Bristol . Older members of Bristol SME will remember him as will people who worked in AMD . He was a true Mechanical Engineer who could turn his hand to anything and almost always achieve success .
                          We got on well and had frequent long talks . Like me his work and hobby had long since merged – professional workplace and home workshop were just extensions of one another !
                          Perhaps some people that knew him could tell us more about his activities .
                          In those early days of mine in industry there were lots of people in Engineering companies interested in Model Engineering . The interchange of ideas between model engineering and full size work was sometimes fruitful – I can't tell you specifics but several difficult design problems in Pegasus , Olympus and RB199 engines were solved by Model Engineers in their home workshops !
                          It was fair exchange – many a large model engine casting was machined in the tool room .
                          Regards ,
                          Michael Williams .
                          #108993
                          MICHAEL WILLIAMS
                            Couldn't get back in to edit but this is corrected text :
                            Westbury was well trained as an Artificer and had I believe a Higher Technical Certificate – not a bad qualifcation to have achieved pre war .
                            (Whiittle himself had an engineering degree )
                            Edited By MICHAEL WILLIAMS on 17/01/2013 12:00:35
                            #109031
                            Roderick Jenkins
                              We won't ever know who the great model engineers are if they don't put their head above the parapet. I think there are Great Experts and they are the ones who have offered us the benefit of their knowledge by writing for ME. With his style, designs and plain good sense I think ETW was the greatest, surpassing LBSC because ETW told us much of the work and reasoning behind his offerings (and by admitting that there was no definitive to the size of valve springs!). ETW was clearly also respected by his more academic peers; Chaddock and Nevil Shute who clearly, in his patrician way, partly based his hero in "Trustee from the toolroom" on ETW. In my opinion only Tubal Cain has come close to having the same authority on his subject.
                              cheers,
                              Rod
                            Home Forums I/C Engines Topics
