Posted by Johan van Zanten on 12/09/2010 11:17:25:
> Hi all,
I am currently constructing a 1910 Fairbanks-Morse RN engine from scratch. I make use of the plans of Pacific Model Design but I build in a smaller scale ( 1: 10 ) My engine is a 3 cylinder in line engine with a bore of 30mm and a stroke of 40mm and has valves in head. It has, like the prototype, 3 carburettors with 4 fuel needles each end low tension make and brake ignition.
Fairbanks-Morse
Old carburettors
When I was ready to test the engine it started almost immediately but it proved to bee impossible to get a proper carb. setting. It was also impossible to restart the engine when cooled down due sticky and malfunctioning igniters. Cleaning up the axels and contacts was the only way. I (temporary) changed the ignition to the proved high tension ignition system and used Rimfire plugs in the houses of the igniters, witch are dummies now. The breaker points and distributor are placed in the engine base and driven by a gear train from the crankshaft. These modifications cured the (re)start problems.
New ignition
Next I made a new intake manifold with only 1 carburettor and 1 throttle valve. The carburettor used is an auxiliary air valve type witch gave good service on my earlier Holt 75 engine.
New carburettor
At last the engine came to life! Starting is excellent now and under load it runs beautiful at 500-600 rpm. But when I release the load it starts to misfire and sounds like a 3 cylinder 2 stroke running idle.
Slowly making the mixture richer results in galloping and black smoke, while leaning out results in opening the throttle by the governor to maintain a constant speed. Only with a (partly) open throttle the engine runs ”decent” and sounds like an old fashioned caterpillar ( Beautiful ).
Is there anybody out there to shine a light on my problem?
Johan van Zanten, The Netherlands. >
Edited By Johan van Zanten on 12/09/2010 11:25:35
Edited By Johan van Zanten on 12/09/2010 11:28:34
Edited By Johan van Zanten on 12/09/2010 13:34:45
Edited By Johan van Zanten on 12/09/2010 13:39:32
