3/8″ BSF stainless steel grub screw supplier?
Home Forums General Questions 3/8″ BSF stainless steel grub screw supplier?
  • #74084
    Tony Pratt 1
      @tonypratt1
      My apologies for asking but this is my last hope. I am after a few 3/8″ BSF x 1″long stainless steel grub screws. This is for a custom built carp fishing rod rest project I am building for a co-worker. I have trawled the internet for hours and searched all the usual suppliers, I can buy any thread apart from the one I want. Does any one know if such a thing is still avaliable?
      Thanks for any help,
      Tony
      Tony Pratt 1
        @tonypratt1
        #74087
          Do they have to have a hex socket? could you not just cut a screwdriver slot in a bit of threaded rod or cut the end of a bolt or screw.
          They are also known as “socket set screws” may throw up a few different results on your favorite search engine.
          J
          #74088
          Tony Pratt 1
            @tonypratt1
            Hi Jason, yes I may have to do that if I can’t get any ready made ones. I’m off to try a new search now.
            Tony
            #74090
              Also if you can find them in a shorter length, just add a slug of brass between the shaft and screw end with the added bonus you won’t damage the shaft.
              J
              #74091
              NJH
                @njh
                Hi Tony
                Try here emkay – he lists 3/8 BSW stainless socket cap screws at 1″, 1 1/4″ and 1 1/2 ” long.
                Oh whoops sorry – looking again at your post I see you need BSF .
                It is worth contacting him however as I’ve found him very helpful and quite quick.
                Norman
                #74098
                V8Eng
                  @v8eng
                  Hi.
                  You could try this supplier.
                  Regards.
                  Edited By V8Eng on 28/08/2011 17:36:19
