I run a flash steam hydroplane and the hull is made of mainly 1/32 marine ply for lightness.
It is glued with 2 part epoxy and at times when things get a bit out of hand the heat softens the epoxy and causes joint failure sometimes with disasterous results.
There are toughen epoxy adhesives that I used to use in the car body repair trade but the one that was used would still soften with heat.
A friend once gave me a cataloque with some industrial epoxy that would probably do but they are no longer trading.
The sort of heat causes the plywood etc to char.
This nomally only happens if excess fuel is pumped to the burners if there is drive or prop failure.
I require an adhesive to bond wood and metal, to be flexable and withstand heat that chars wood.
Any suggestion of suitable glues that you can buy in a small quantity would be welcome
Windy
