Proxxon machine tools
Home Forums General Questions Proxxon machine tools
  • #21901
    Michael Leek
      @michaelleek30717
      Michael Leek
        @michaelleek30717
        Does anyone have any experience of Proxxon tools? I’m considering getting a lathe, saw table, drill/mill, sander, thicknesser, etc, etc. Are they accurate, reliable and can they be used to fine tolerances?
        #71999
        ady
          @ady
          They certainly look like nice wee bits of gear, you don’t see much second hand stuff reach the market though, they seem to be quite rare.
          Cowells stuff seems to be a lot more common in the UK.
          #72000
          Michael Leek
            @michaelleek30717
            Problem with Cowell’s is that they seem ridiculously expensive!
            #72003
            ady
              @ady
              A cowells is a “proper” lathe with a proper bed, large slotted cross slide, backgear etc
              If you’re new to this game I wouldn’t go for a brand new unit either.
              I’d get a decent second hand one and bash it about and make mistakes on it before splurging out on a brand new bit of kit.
              #72004
              Michael Leek
                @michaelleek30717
                Thanks ‘ady’ but your replies don’t actually answer the question I posed in opening this thread – which was about Proxxon tools, not Cowell’s!
                I’m not ‘new to this game’ but had to get rid of much equipment a few years ago for a variety of reasons. Now I’m in a position to restart.
                #72005
                Michael Leek
                  @michaelleek30717
                  #72006
                  Steambuff
                    @steambuff
                    I have used Proxxon tools and on the whole find them excellent, the build quality is what you would expect from a German Company.
                    The accurracy is good, better than a ‘Far Eastern” unit straight out of the box.
                    They tend to be on the smaller size, so it depends on what you are going to use them for and which models you are looking at.
                    Michael Leek
                      @michaelleek30717
                      Thanks Dave.
                      My intended use is for small scale (1:96 and 1:192) model ships and small engineering projects such as the Stuart compound steam engine.
                      The tools I’ve been considering include the following;
                      Lathe PD 230/E
                      Micro miller MF 70 or the more expensive Micro miller FF500
                      Bench drill machine TBM 220
                      Table saw FET
                      Disc sander TG 125/E
                      There are other tools I’m interested in but these are for starters!
                      #72008
                      Spurry
                        @spurry
                        I have a couple of the older model of FET table saw. On the new model, one feature that seems to have improved is the micro-adjustment feature, as mine have none. I would recommend carbide blades as the resulting finish requires very little sanding.
                        Pete
                        #72009
                        Roderick Jenkins
                          @roderickjenkins93242
                          Michael,
                          I’ve seen good reviews of the table saw by fellow musical instrument makers. Would, I think, be ideal for model ship making. Professionly I’ve used the Proxxon TC circular saw blades and the small bench drill – good high quality kit.
                          Rod
                          #72026
                          Billy Mills
                            @billymills
                            The table saw is very useful and quite unique. Would think carefully about the lathe and mill.
                            The lathes are very expensive against other kit of comparable quality.
                            The MF70 mill has an Ali and plastic table and is VERY small but is one of the few small mills that will run up to 20,000 rpm for 1-3mm tooling. Well suited for very small work on soft materials in limited quantities.
                            Worth considering Sieg small mills and drills against the Proxxon’s.
                            Would not rave about build quality at all, we are talking plastic and Ali extrusions for most models. These are miniature hobby tools well suited for miniature work in soft metals, plastic and wood with mostly very small brushed motors.
                            A few other posts have appeared, search PROXXON as the keyword.
                            Happy milling
                            Billy.
                            #72028
                            Michael Leek
                              @michaelleek30717
                              Thanks Rod, Pete and Billy.
                              Billy: what do you meanby ‘small quantities’? Are you saying that Proxxon machine tools are not designed for contrinuous use? And which lathes do you think I should look at?
                              I’ll do more research anyway and I’ll certainly check out the Sieg mill/drill, though it does seem as the Proxxon table saw is a good bet.
                              #72029
                              Michael Leek
                                @michaelleek30717
                                By the way, is the Axminster SIEG C1 Micro Lathe Mk2 any good? Size-wise it fits my purpose.
                                However, I note from Dave above that he suggests machine tools made in Asia are not necessarily as good.
                                #72041
                                Billy Mills
                                  @billymills
                                  Well if you are a hobby user you are not going to be running the same job all of the time so such factors as the hardness of the ways is not so important. Equally if the machine packs up it is an inconvenience rather than a disaster. I would not want to run any of my Proxxon tools continuously -they are NOT industrial tools but they are well designed for hobby use, many of their machines use plastic and ali ways.
                                  I do use Proxxon tools, my use is in small scale prototyping in soft materials. It is all down to what your applications and expectations are and finding your own best value. My opinion is that Proxxon tools are very well styled and attractive but they are mainly hobby level tools.
                                  If you can get to a stockist – such as Axminster – get to have a good look, feel the weight and get a test drive if you can.
                                  Lathes and all other machine tools are a bit like religion- everyone has their own set of ideals and values. I would suggest that if you are going to use your new machines much then visit some local ME clubs and find out what other people use and have a try if possible. My own workshop is based around ex-industrial and industrial machines with Proxxon tools here and there for low volume small stuff.
                                  Happy Milling
                                  Billy
                                  #72043
                                  Michael Leek
                                    @michaelleek30717
                                    Thanks for the detailed reply Billy. I’ve only been up here in Scotland for three years and have yet to seek out an ME club – but it’s a good suggestion of yours, as is trying a local Axminster stockiet (probably few and far between up here!).
                                    #72051
                                    Dusty
                                      @dusty
                                      Michael
                                      If it is the Stuart Launch engine you are thinking of then I think the little Proxxon lathe would be on the small side. I would venture to suggest that you should be looking at a 3 or 3 1/2″ lathe minimum, which would be in the same sort of price range as the Proxxon.
                                      I have used the Proxxon drill/grinder for several years and to my mind it is superior to the other well advertised competitor.
                                      #72054
                                      Donald Mitchell
                                        @donaldmitchell68891
                                        Michael
                                        Where are you in Scotland?
                                        Donald Mitchell
                                        Castle Douglas
                                        Bonnie Scotland
                                        DG7
                                        #72073
                                        Michael Leek
                                          @michaelleek30717
                                          Billy: nearest Axminister is in Cheshire so not much good there unfortunately!
                                          #72074
                                          Michael Leek
                                            @michaelleek30717
                                            Dusty: no, it wasn’t the Stuart launch engine I was thinking off – nothing as big, though it would be a great project, especially as marine steam engines are a particular interest, but I have to be realistic in terms of workshop space – only 10′ x 8′ (arriving tomorrow too!). Thanks for the advice on the Proxxon drill/grinder.
                                            What about the Axminster SIEG C1 Micro Lathe Mk2? Worth considering?
                                            #72075
                                            Michael Leek
                                              @michaelleek30717
                                              Hi Donald
                                              I’m in Portknockie, Bannffshire (postcode AB56). Almost equi-distant by road between Aberdeen and Inverness.
                                              #72076
                                              AndyP
                                                @andyp13730
                                                Michael,
                                                My first lathe, 5 years ago, was a Sieg C1 but the Chester variety. I have built most of a 3 1/2″ gauge Rob Roy on it so far and a lot of little bits for other jobs.
                                                It is not the most rigid or accurate lathe and the topslide is a pita.
                                                I now have a Cowells and a Boxford AUD as well and still use the C1 for anything that will fit on it and doesn’t need high accuracy, it is so quick to set up and quiet in operation. It helps that I have just about every extra available – I could never afford them for the Cowells.
                                                Cheers, Andy
                                                #72078
                                                Michael Leek
                                                  @michaelleek30717
                                                  Interesting Andy. Can you be more specific about the accuracy of the Sieg? One thing I will need to turn are canons at 1:96 and 1:192 scale (i.e. small scale). For each scale they would need to be as identical as possible.
                                                  As for Cowells – they are well outside my budget too!
                                                  #72079
                                                  blowlamp
                                                    @blowlamp
                                                    Could you run to a C3 mini-lathe from somewhere like Arceurotrade or Chester etc?
                                                    The advantage is their popularity and range of accessories. Commonly available tooling is a plus point too.
                                                    Martin.
                                                    #72131
                                                    AndyP
                                                      @andyp13730
                                                      Michael, I’ll try but I don’t have an engineering background, well not this sort of engineering anyway.
                                                      The saddle is very short so even with the gibs adjusted as tight as possible while allowing movement there is still detectable play – think rotary looking vertically down on the saddle.
                                                      There is simple backlash adjustment for the leadscrew but it soon reappears, likewise for the saddle traverse, mind you backlash can be allowed for by working methods – I have learnt something at least.
                                                      It doesn’t compare in any way with the Cowells for “feel” – I can’t put it any better than that.
                                                      For the size of component you are working on the Proxxon may be a better bet – but I have never seen one.
                                                      Variable speed is great though
                                                      It strikes me you are down to watchmakers sizes so maybe consider that category of machine – price a big issue again I suspect.
                                                      Hope my ramblings help a little.
                                                      Andy
