Setting Z on milling machine
Home Forums General Questions Setting Z on milling machine
Viewing 2 posts - 1 through 2 (of 2 total)
  • #64116
    Nobby
      @nobby
      Hi
      Try this
      Make an accurate 5 mm hardened setting peice. dont use your best slips
      Using electronic hand wheel . wind quill down carefully touch setting peice.
      go to controls Datum set Z +5 enter . After make sure you send Z home to clear job and clamps.I suppose you cold use this for Touching down as well
      Regards Nobby
      Nobby
        @nobby
