Inside cylinder casting patterns
Home Forums General Questions Inside cylinder casting patterns
  • #21727
    Stuart Davies 3
      @stuartdavies3
      Stuart Davies 3
        @stuartdavies3
        Hi,
        I was wondering if anyone has made some patterns for inside cylinders? I intend to produce some for a 5″ duchess, they basically consist of a block with four cores in, two small for the valve chests and two large for the pistons. The underside has a bit of shape and detail to it, which makes it impossible to mould the pattern vertically, as this detail would catch the sand when drawn out. I’m not a fan of loose pieces particularly, but any help would be most welcome. The four cores seem to cause the most problems as two parting lines are created-is it necessary to make a 3-part moulding box to create the two parting lines? Experienced foundryfolk please lend advice/photos!
        Cheers ,
         Stuart
        #55628
        Bryan Rozier
          @bryanrozier80712
          Hi Stuart,
          With the outside being mainly rectangular is there any point in making a casting?
           Wouldn’t it be easier / cheaper to hack it out from the solid?
          Cheers
          Bryan
          #55706
          Brian Oldford
            @brianoldford70365
            If you are only intending casting a few from time to time go with the 4 piece pattern in a 3 piece box. (http://en.wikipedia.org/wiki/Core_(manufacturing)#Cheeks)
            #55715
            Stuart Davies 3
              @stuartdavies3
              What a cheek! Thanks for your reply regarding cheeks, I was hoping that I wouldnt have to make a 3 part box, and split the pattern into 4 pieces (maybe just two pieces so that the centre portion could be removed from the cheek, the actual parting lines themselves, I think could be created by the ‘oddside method’, thus preventing the need for the pattern to be split into 4 pieces. Please keep suggestions coming, I’ll post some photos of the final method.
