Model Engineer Clock
Home Forums General Questions Model Engineer Clock
  • #43422
    bellerophon
      @bellerophon
      I have built the above and have been unable to get it to run for more than an hour at best. I have double checked the escapement (the going train is free and correctly aligned) and my local clock repairer suggests a weaker suspension spring or lighter pendulum which helps but doesn’t cure the problem) but the escapement hangs up at different teeth on the escapement wheel.
      The clock is on a level surface, the wheel is cut to the correct angles – anyone else have this problem or any suggestion as to how to get it going?
      bellerophon
        @bellerophon
        Problems getting it to run!!
        #43426
        keithmart
          @keithmart
          The fact that the escape wheel stops at different places suggests that the problem is further back in the chain.
          Check the wheels carefully and remove any stiffness in the meshing.
          Bear in mind that from the great wheel to the escapement is a very high gear ratio, and it doesn’t take much to stop it.
          Keith
          Leeds UK
          #43427
          bellerophon
            @bellerophon
            Many thanks – I’ll try that but it runs very freely!
            #43513
            bellerophon
              @bellerophon
              Keith
              Thanks for the tip – you were right (as was the original construction article) Model engineers make things too tight! I disconnected the escapement, took the clock apart and put a mixture of Brasso and clock oil in each pivot hole, reassembled the clock and ran it at bottom speed on the lathe for 30 minutes, the cleaned all up and IT WORKS!!
              Hope anyone else with the problem is helped by this so I’ll post it in the thread
              #43517
              keithmart
                @keithmart
                Hi
                As I always say,  ’It is easy to make a clock, but, it is a lot harder to make it go!!’
                Glad you got it sorted.
                regards Keith
                Leeds UK
