Just abandoned another attempt, using one of the exercises in the more obvious tutorials. (Goodness know where I'd found that micrometer, but it was in there somewhere.)
This one is a journal: an angle bracket with a boss and bearing hole at the top, and a broad foot with bolt holes. A later exercise apparently puts two of them on a base to support a simple roller.
It's in Synchronous mode – yes – all set. (I think SE defaults to that for a new drawing.)
This also uses a very different, more comprehensive and more comprehensible tool-bar from the Ordered one mode, so there are clearly major differences between the two modes; for very advanced users. This is what happened:
1) Confusing stuff about two identical-looking plane indicators. It uses the word "co-ordinates" but with no origins or scales, so meaningless there.
2) Draw the 'Base Feature', a rectangle to a given size "By Centre". Where? It does not show its own centre, and lies randomly on the screen, not on a defined origin.
It's also meant to lie flat on the floor (XY plane). Mine was standing on edge (XZ).
3) Something called QuickPick. Oh – will that set the plane in which to draw the object, and let me turn the rectangle flat?. No – it was tricky to use and did nothing.
4) Now it says draw the rectangle. Hang on! I've already done that 'cos it said so! Still, QuickPick apparently said I have selected the correct plane, because its menu had only two entries, "Base" and a mystery symbol, and I had clicked on 'Base'. I deleted that first rectangle and drew a new one. It still stood upright. No obvious way to draw it flat, nor to turn it flat.
5) Gave up.
The XZ plane seems is the default. Whatever Quickpick is meant to do… I can't make it do it. This for just a single, flat rectangle, not the thousands of 3D objects forming each of the Siemens web–site show-offs.
At least Synchronous mode draws a rectangle as a full rectangular area, not as four disconnected lines round empty space, as Ordered mode has it.
It seems no matter how carefully I follow the instructions, nothing does as it says or leads me to expect, it will.
Do such-and-such, it tells me, then "Observe the …." . Yes – I have done such-&-such, very slowly and carefully, and am observing it but even if looks like the tutorial's screen-shot, what am I supposed to see in it?
It's all very disheartening. TurboCAD was hard enough but SE seems even worse, even allowing for they being vastly different in approach and tools. It's also more discouraging to see the pretty pictures that CAD publishers use on their own web-sites to show the software's potential.
