Odd Problem with Lofted Solids
Home Forums CAD – Technical drawing & design Odd Problem with Lofted Solids
Viewing 25 posts - 1 through 25 (of 34 total)
  • #273750
      Help! If I create a lofted solid in turbocad, it appears to create a surface rather than a solid. I've checked that both the generating 2D objects are closed (they are just rectangles with rounded corners.
      I'm confounded by this!
      Edit: I seems I need to change the properties of the lofting tool to create object as solid, but it only give me the option of 'surface' – it seems this is a limitation of not having TC Pro.
      Edited By Neil Wyatt on 26/12/2016 11:11:33
        Muzzer
          @muzzer
          Fusion 360 Ultimate – free, zero cost, gratis….
          #273756
            Posted by Neil Wyatt on 26/12/2016 11:06:52:
            Help! …
            Solid = an infinite number of surfaces in a stack, so it's bound to need the Pro version.
            devil MichaelG.
            #273782
              Posted by Michael Gilligan on 26/12/2016 11:39:44:
              Help! …
              devil MichaelG.
              Are you sure this will work?
              It took me ages to stack an infinite number of surfaces, but it's still zero thickness.
                Posted by Muzzer on 26/12/2016 11:19:15:
                Say NO to New Learning Curves!
                  Posted by Neil Wyatt on 26/12/2016 14:59:56:
                  Only conceptually angel
                  #273799
                  Ed Duffner
                    @edduffner79357
                    Create Solid from Surface ?
                    Ed.
                    #273802
                      That's very interesting, Ed
                      I don't have TurboCad, so I can't test it, but; it looks suspiciously like the two open ends have simply been 'skinned-over" … What happens if you slice that 'solid' object ?
                      Just curious
                      Ed Duffner
                        @edduffner79357
                        Hi Michael,
                        I'm afraid I don't have TC any more (used to have a very early version), this was just a quick search on the net. I know some programs do make a solid object with similar functions, dare I say Fusion 360 for one smile p Perhaps Neil can check out the function and let us know?
                        Edit: It could be one of the limitations Neil mentioned.
                        Ed.
                        Edited By Ed Duffner on 26/12/2016 17:36:22
                        #273809
                          Posted by Ed Duffner on 26/12/2016 17:07:58:
                          That's where I discovered it only works in Pro and Pro Platinum
                          #273814
                          blowlamp
                            @blowlamp
                            I'm learning Fusion 360, mainly for the CAM features. However, I can't see me moving from MoI as my main CAD application any time soon. In MoI, a solid is created from any surfaces that are water-tight simply by selecting them and clicking on the Join icon. Clicking the Separate icon turns them back to surfaces again. So quick & simple!
                            "Solid = an infinite number of surfaces in a stack,"… What a weird concept that is! no
                            Martin.
                            #273817
                              Posted by blowlamp on 26/12/2016 18:35:31:
                              It was offered as a bit of fun, Martin … But, as you find it objectionable; could you please tell me what is wrong with it ?
                              Take any solid, and peel-off a surface [being something with zero thickness] … What remains ?
                              Gary Wooding
                                @garywooding25363
                                TC Deluxe cannot create solids. All 3D models are hollow surfaces.
                                The Pro versions create solids by default.
                                Edited By Gary Wooding on 26/12/2016 19:00:11
                                #273825
                                John Stevenson 1
                                  @johnstevenson1
                                  Neil, out of interest, what version ?
                                  #273827
                                  blowlamp
                                    @blowlamp
                                    Posted by Michael Gilligan on 26/12/2016 18:41:49:
                                    Oh, I thought it may have come from the documentation.
                                    I just don't see how stacking zero thickness surfaces can become a solid.
                                    I think a solid is classed as a closed volume, so removing a surface probably makes it an open volume.
                                    Martin.
                                    #273829
                                    Mark C
                                      @markc
                                      I like the idea, a bit like straight lines being arc of infinite radius… and anyway, we have surfaces of zero thickness so why can't you expand the idea with some lateral thought? Apart from all that, apparently we live in a world of 3D printing = solids made up of sequential surfaces with some thickness, although they are trying to get them closer to zero!
                                      Mark
                                      #273832
                                      blowlamp
                                        @blowlamp
                                        Posted by Mark C on 26/12/2016 21:14:47:
                                        Mark
                                        Hmm, so is an arc made up of lines of infinitesimal length? face 1
                                        Martin.
                                        #273833
                                          Posted by blowlamp on 26/12/2016 20:56:34:
                                          (a) I just don't see how stacking zero thickness surfaces can become a solid.
                                          (b) I think a solid is classed as a closed volume, so removing a surface probably makes it an open volume.
                                          (a) … as I said, it was just a bit of fun; I did mention stacking an infinite number of them
                                          (b) … I think that re-states the problem that Neil is having. [i.e. he wants solid solids]
                                          blowlamp
                                            @blowlamp
                                            Posted by Michael Gilligan on 26/12/2016 21:48:22:
                                            Neil's problem is he needs a more intuitive CAD application.
                                            Martin.
                                            #273843
                                            Mark C
                                              @markc
                                              "Hmm, so is an arc made up of lines of infinitesimal length?" Certainly small lines especially if it is a cheap system!!!
                                              Mark
                                              #273867
                                              Gary Wooding
                                                @garywooding25363
                                                Neil,
                                                If your requirement is to create solid models for 3D printing, then download and install MeshMixer which is totally free. Get it from HERE
                                                It will accept STLs and there is a command to convert to solid.
                                                An alternative that I, and lots of others, have adopted is Fusion 360. Its certainly a paradigm shift from TurboCad, but I'd be surprised if, after spending the time getting used to it, you didn't consider it a vast improvement over TurboCad. I've switched to using it for all my 3D modelling, but still use TurboCad for 2D drawing because, at the moment, its far better than Fusion.
                                                #273892
                                                  It's version 9.
                                                  As pointed out all TC deluxe 3D shapes are 'surfaces' which doesn't seem to upset a 3D printer.
                                                  This makes the problem (solved by another approach) curious:
                                                  If I place a cube to go through one side of a larger cube, then subtract it, I get a shape a bit like a Belfast sink. But i want a tapered shape more like a bath tub.
                                                  If instead the two shapes are lofted with a taper, rather than extruded squares, then a hole is cut in the intersected side of the larger shape and no surface is created for the 'inside' of the bath i.e. it isn't a 'closed' surface any more.
                                                  Weird.
                                                  I solved it by subtracting an extruded rectangle with rounded corners from a larger one, then moving the points at the narrow end of the taper towards the mid-line. This kept the radius of the corners constant bit anglesd teh edges, which looks fine.
                                                  #273896
                                                    Neil, can't you extrude cut with a draft angle? Alibre allows that not sure about your TC.
                                                    Edited By JasonB on 27/12/2016 13:32:36
                                                    #273901
                                                      Not in deluxe.
                                                      I did get there in the end, any guesses what this is?
