Yup and there are some good videos on the Onshape site too.
Not had long to play with it so far, but am reasonably impressed with what I've seen. The interface is pretty clean and 'sparse' so it's not immediately obvious sometimes how things work (no reassuring texty menu to delve into) but after watching some of the tutorials it becomes clear and is actually quite elegant. I think organising the parts and sub-assemblies within each 'document' will take some getting used to, to keep everything manageable and clear and not ending up with a gazillion tabs. I've also yet to get my head around how its assembly constraints ('mates' ) work – it's not like Alibre in that respect (but otherwise the modelling process seems very similar really).
The graphics all work fine, and I'm using it on a pretty bog standard Windows 7 office computer without any fancy graphics cards or excessive RAM (4Gb) and a quite high res screen (1680×1050). Even the most complex sample models (e.g. the lightweight CNC router) can be rotated/zoomed etc without noticeable lag. Only if moving some of the parts within that assembly did the display lag seriously. Then again my old Alibre CAD works fine too on the same machine.
The system is a bit slow sometimes to load up models, but once they're up it's fine.
I don't think the 'five active document' limitation on free accounts will be a serious one at all – each can contain unlimited parts and sub-assemblies. There is a file size limit (5Gb) for free accounts too of course – but can't be sure if that might eventually be an issue… my initial test doc has only used 1.5 Mb so far…
They are still adding features quite rapidly – think an update just went through and when I logged on just now there are now 'gear mates' for assembling working gear mechanisms
Edited By Bikepete on 13/03/2015 22:00:45
