Some more photos of mine, as you will see there are several probes that can be interchanged to use on very narrow groves and to increase the usable diameter. I use either a calliper or micrometer to make the initial zero, with care they can give good accuracy.
The additional clamp is I believe so the dial gage can be used units own on a scribing block etc.
