In the pile of bits and pieces that came with my Boxford lathe, there is a nice MT3 collet holder with drawbar – I have deduced that it takes Double Taper or DT collets in the Z size range.
Unfortunately I only have one collet, a 7/16" and it looks like they are not all that common and not cheap when you can find them – around £25 each or more.
Do you think it's worthwhile trying to get any more, or should I just go for ER32 instead? Which would also make it possible to pass material all the way through with the right sort of holder.
Bonus question – if I keep it just for doing some light milling with a vertical slide, what diameter milling cutter would have a 7/16" shank?
Thanks,
Rob
