Q-Cut inserts
Q-Cut inserts
Home Forums Workshop Tools and Tooling Q-Cut inserts
  • #20883
    Bob Unitt 1
      @bobunitt1
      Looking for parting-tool inserts
      Bob Unitt 1
        @bobunitt1
        I have an early Greenwood 'Q-cut' Mk 2 parting-off tool. Now Greenwood is gone, I need to find an alternative source for the inserts. Can anyone point me in the right direction, please ?
        #627576
        Oldiron
          @oldiron
          Hi Bob, This post may help.
          regards
          #627577
            The insert is a Sandvic QD-NF-0250-0002-CM 1125. Pop that into google for suppliers though finding singles may be a problem.
            Edited By JasonB on 04/01/2023 18:28:02
            #627580
            DC31k
              @dc31k
              Posted by Oldiron on 04/01/2023 17:45:45:
              Be aware that there were two versions of the tool produced. The post to which you refer relates to the Mark I version and the insert code mentioned there (151.2 etc.) only fits that version.
              This thread is about the Mark II version, taking a different insert code, the one mentioned by JasonB.
              #627587
                Have a look at JB Cutting Tools, or Arc Euro.
                They may have suitable alternatives.
                #627603
                duncan webster 1
                  @duncanwebster1
                  Is jb still going, I can't find her on the interweb
                  #627604
                  Grindstone Cowboy
                    @grindstonecowboy
                    JB seems to be exclusively selling via Ebay these days (and in person at shows).
                    Rob
                    #627605
                    David George 1
                      @davidgeorge1
                      JB is on eBay and phone now. 01246 418 110 jennblackwel-6
                      David
                      #627724
                      Bob Unitt 1
                        @bobunitt1
                        Posted by DC31k on 04/01/2023 18:48:28:
                        I thought that in the Mk 1 the insert was retained by a screw ? Anyway, a picture being worth a thousand words, here is the Q-cut in question :-
                        Q-cut parting tool and inserting device
                        Q-cut insert
                        #627731
                          That's the one the code I posted fits, same 1125 on the insert as at the end of the code
                          #627733
                          Roderick Jenkins
                            @roderickjenkins93242
                            I'm note sure if there was an official mk I or II designation. Back in 2018 Greenwood were advertising the new KIT-QD version. I approached Greenwood at the Midland show and bought a couple of the previous model (1125) tips for my KIT-Q-CUT. The Q cut works very well but e.g. ARC sell similar systems and they work fine for considerably less money. When my last Q cut tip dies I will transfer my affections to a cheaper system for my rear toolpost.
                            Rod
                            #627737
                            DC31k
                              @dc31k
                              Posted by JasonB on 05/01/2023 18:55:16:
                              I believe the 1125 is only the carbide grade. That insert will not fit the one in his picture.
                              The one pictured is not what I would call a Mark 2 version. The insert for the one pictured is the 151.2 code, similar to the one here:
                              https://www.zoro.co.uk/shop/cutting-tools/parting-inserts/n151-2-250-5e-insert-grade-1145/p/ZT1006152P
                              It is the newer version that takes the QD NF insert, pictured here:
                              https://www.sandvik.coromant.com/en-us/product-details?c=QD-NF-0250-0002-CM%20%201125
                              #627740
                                You could be right, just took another look at the one Greenwood had for sale yesterday and the hole the insert goes into is different being one that is spread open by the tool rather than the tool just pushing the insert out.
                                #627741
                                Bob Unitt 1
                                  @bobunitt1
                                  Posted by DC31k on 05/01/2023 19:17:56:
                                  Ouch, £160 for a minimum of 10 surprise Does anyone know of a source of single inserts ?
                                  Incidentally – the tool is 2-7/8" long, and the insert 3/8" long.
                                  #627743
                                  Roderick Jenkins
                                    Just to confuse the issue, I have one of the "pipless" slanted tips which has 4125 engraved on it.
                                    #627884
                                    Martin 100
                                      @martin100
                                      Posted by Bob Unitt 1 on 05/01/2023 19:35:23:
                                      https://www.rileyshutt.co.uk/Products/001100020001
                                      A bit cheaper than zoro and in singles
                                      Edited By Martin 100 on 06/01/2023 15:26:25
                                      #627900
                                      lfoggy
                                        @lfoggy
                                        I Have the same tool purchased from Greenwood some 10 years ago. I bought 10 inserts at the same time. Pic of tool and insert pack below. Fortunately the inserts last for ages but I am now running out as well……
                                        Edited By lfoggy on 06/01/2023 16:04:34
                                        #627902
                                        lfoggy
                                          @lfoggy
                                          Inserts available from Cromwell for £110 for 10….should last me another decade of use.
                                          #627935
                                          Roderick Jenkins
                                            Posted by Martin 100 on 06/01/2023 15:18:13:
                                            Good find but, sadly, need to be ordered in boxes of ten sad. I'm glad to see they are still available. I could do with a couple of spare tips. I'd be happy to buy a box of ten and split them at cost if anybody is interested.
                                            Rod
                                            #627972
                                            Martin 100
                                              @martin100
                                              Many apologies, felt sure I’d bought them individually many years ago when I also bought a sandvik parting tool blade from RileyShutt as mine from greenwood was becoming a bit tired and prone to losing grip on the insert.
                                              The double ended sandvik one can be cut in half, drilled and countersunk to replace the greenwood sourced items, the result is blade a bit shorter overall but it still parts off the same diameter. (This was sometime before sandvik QD arrived)
                                              #627982
                                              IanH
                                                @ianh
                                                I have pm'd you Rod regarding a shared purchase.
                                                Ian
                                                Edited By IanH on 07/01/2023 12:14:58
                                                #627983
                                                duncan webster 1
                                                  @duncanwebster1
                                                  Posted by Martin 100 on 07/01/2023 10:58:54:
                                                  Using a countersunk screw in shear is not ideal. It would be better with a close fitting dowel at the business end and the screw just behind. Then the dowel would take the shear and the screw would just hold it to the tongue. As you are not trying to make 2 out of one it can be a bit longer.
                                                  #627984
                                                  Bob Unitt 1
                                                    @bobunitt1
                                                    Posted by lfoggy on 06/01/2023 16:03:59:
                                                    I bought mine 20 years ago with 3 inserts, and I've just started on the 3rd. I can see numbers on the boxes in your picture, do any of them relate to the inserts ?
                                                    #628026
                                                    Roderick Jenkins
                                                      Any body else interested in sharing a box?
                                                      Rod
