Differential Screws
Differential Screws
Home Forums Workshop Tools and Tooling Differential Screws
  • #20831
      I am probably being dim …
        I am aware of how ‘differential screw’ adjusters usually work [screw threads with different pitches, working in tandem] … But these have me stumped:
        https://www.ebay.co.uk/itm/254633999168
        Could some kind soul please post a rough sketch to explain how left and right hand threads of the same pitch can provide differential adjustment ?
        … My brain hurts !
        John Haine
          @johnhaine32865
          I don't think they are the same pitch.
          #619044
            Posted by John Haine on 29/10/2022 22:02:23:
            I do, John … that’s why it’s puzzling me
            M8x1mm
            Left-hand one end, Right-hand t’other
            Credit Tony4Cats
            Edited By Michael Gilligan on 29/10/2022 22:10:50
            #619047
            bernard towers
              @bernardtowers37738
              How does that make them differential?
              #619048
                Posted by bernard towers on 29/10/2022 22:27:32:
                That was my question ^^^
                They are listed as such crying 2
                Neil A
                  @neila
                  They are not really what I would call a "differential screw adjuster". As you say, they usually have threads of different pitches and are the same hand to make fine adjustments.
                  These are just like the threads in the middle of a pair of spring bow compasses, or track rods on a car. As you wind the screw the "nuts' on each end are either pulled together or pushed apart. An adjusting screw, but not differential. Perhaps the description sounds more technical for an advertisement than simply calling it a left and right handed adjusting screw!
                    In the absence of any explanation … I think you must be right, Neil
                    I asked the question because I was beginning to doubt myself
                    … Looks like I might be O.K. after all smiley
                    Trouble is … He also lists these: https://www.ebay.co.uk/itm/313125445600
                    … which make far more sense.
                    Edited By Michael Gilligan on 29/10/2022 22:49:36
                    #619054
                      Get over it. He just did a cut and paste job on the description without thinking much about it. If you look at his sales count he is a garage trader shovelling out the stuff by the wagon load so isn't going to put a measurable amount of QA checking on his sales pitch.
                      #619059
                      Ady1
                        @ady1
                        At sea we called them bottle screws but turnbuckle or tensioner screw is probbly a better description
                        #619060
                        Mark Easingwood
                          @markeasingwood33578
                          I don't know about their use in engineering tooling, but, the ones in your first picture are used in spindle moulder tooling, (wood machining), along with an olive, (cone shaped nut), to hold the wedge, which locks the knives into the block.
                          It is not very obvious how they are used from the links below, I can takeyou a picture on Monday if you want.
                          Screw
                          Olive
                          Mark.
                          #619062
                          Mark Easingwood
                            #619068
                            David Davies 8
                              @daviddavies8
                              Good morning.
                              We use them at work to hold a carbide insert into the toolpost of a scarfing machine on a continuous ERW tube mill.
                              I recently bought some spare ones for the machine and Sandvik do indeed list them under the name 'differential screw'
                              I assume that this is the literal translation to English from the makers mother tongue.
                              Cheers
                                Well, Gentlemen :
                                … aside from Bazyle’s rather stroppy “Get over it.” … I’m grateful for the input.
                                P.S. “Garage Trader” he may be … but he lists some very useful stuff
                                #619078
                                DC31k
                                  @dc31k
                                  Posted by Michael Gilligan on 29/10/2022 22:29:19:
                                  In some sense, they _are_ differential because the rate at which the screw advances (2mm) is different to either of the pitches cut on each end.
                                  If you have assimilated a definition of a differential screw _requires_ it to have different pitches at each end, clearly they do not fall within that.
                                  The eBay listing is confusing as it remarks on the fine adjustment ability of a differential screw, a property which is only true if you adopt the latter definition.
                                  If the diameter is fixed at 8mm, and the application needs 2mm advance, the other option is a 2-start thread, but maybe that is more expensive to produce than the Pushmi-Pullyu.
                                  #619080
                                  DC31k
                                    @dc31k
                                    Thinking about it some more, if we wanted to write a generalised mathematical expression for a differential screw, we would need two inputs for each end of it: the pitch of the thread and the hand of the thread.
                                    If we agree a convention that the pitch of a RH thread is a positive number, we can represent a LH thread in our expression with a negative number.
                                    The fine adjustment mechanism has the same hand at each end and different pitches. We subtract the two pitches and take the absolute value of the result to calculate the differential movement.
                                    That formula works for a length of threaded rod: same hand and same pitch – do the subtraction and you arrive at a differential movement of zero as expected.
                                    For the eBay one, the hand is different but the pitch is the same. Do the same subtraction, but remembering our LH thread is represented as negative, and we arrive at a differential movement of 2mm in this case.
                                    Let us say we have a 1mm RH pitch one end and a 1.25mm pitch LH at the other end. The differential in that case would be 2.25mm. If you happened to need this movement for something, it is hard to buy a tap or die as it is a non-standard pitch. Because of this, it might not feature in the gearbox of a screwcutting lathe.
                                    Edited By DC31k on 30/10/2022 08:28:11
                                    #619084
                                    Michael Horner
                                      @michaelhorner54327
                                      Hi Michael,
                                      From Wikipedia:- (in case of a single lead equal to the thread pitch), and possibly opposite handedness, on which two nuts move. As the spindle rotates, the space between the nuts changes based on the difference between the threads.
                                      This is not the full description, but the word "possibly" may mean not everybody agrees it's differential.
                                      If they are not left and right hand threads I don't see how it could be differential.
                                      My head hurts all the time now!
                                      Cheers Michael.
                                      #619090
                                        The left/right handed combination screws are sometimes called compound screws and other times clamping screws too.
                                        The Free Dictionary defines a Compound Screw thusly:
                                        Compound screw
                                        Also found in: Encyclopedia.
                                        (Mech.) a screw having on the same axis two or more screws with different pitch (a differential screw), or running in different directions (a right and left screw).
                                        See also: Compound
                                        Webster's Revised Unabridged Dictionary, published 1913 by G. & C. Merriam Co.
                                        So it seems both differential and right-and-left screws are types of compound screw. But on the shop floor the blokes using the screws to retain the carbide inserts probably don't give a toss and just refer to them generally as differential screws and get on with the job. Well, the thread on each end is different from the other, in handedness. That's differential enough for practical purposes.
                                        #619092
                                          Good to see this discussion developing yes
                                          I will just mention Norris … who deserves the credit for my first introduction [decades ago] to differential screws:
                                          https://www.leevalley.com/en-us/discover/revisiting-the-past-the-lee-valley-antique-tool-collection/featured-patent-norris-plane
                                            If these screwed studs have the same pitch, and the same hand at each end, rotating the stud, between two fixed members, will merely move the stud between the fixed members, without changing any dimension
                                            If the stud is stationary, and one end member is rotated there will be a a change of overall dimension.i
                                            This what happens with a cylinder head stud on an engine, although it not unknown for threads of different pitches to be used, such as BSW into the cylinder block and BSF for the outer end,.
                                            If the end threads are of different pitch, but the same hand, there will be a fine adjustment, because the advance at one end will differ from that at the other. The coarse fixed end reduces the risk of stripping the fixed thread, while the finer outer thread allows a clamping load to be applied with greater accuracy.
                                            If the threads are right hand at one end and left hand at the other, and the stud is rotated, the device will act like a turnbuckle, either drawing the fixed members together, or pushing them apart..
                                            In the case of a turnbuckle, the end studs remain stationary and the central member rotates to produce the adjustment.
                                            To produce a differential adjustment, the threads have to be different, either in pitch or hand, (As shown in the picture ).
                                            #619102
                                              Posted by Howard Lewis on 30/10/2022 10:07:13:
                                              [my emboldening] … Which is very clearly the case in the example under discussion
                                              It was the leap from ‘turnbuckle’ to ‘differential screw’ which troubled me enough to ask the question.
                                              I shall be very interested to see the detail that Mark has kindly offered to post tomorrow
                                              … largely because the ‘Olive’ that he linked only served to confuse me further.
                                              https://www.whitehill-tools.com/spares-accessories/screws-olives/470S00070/
                                              Edited By Michael Gilligan on 30/10/2022 10:21:31
                                              #619131
                                              old mart
                                                @oldmart
                                                My idea of differential screws is for them to have different pitches, although they would not need to be the same hand. Turnbuckle screws are opposite hands and normally identical pitches. However, I could imaging a turnbuckle with different pitches and the same hand giving a very slow length to rotation movement. Not something I had thought about much before, interesting. They are all very closely related and no concept is wrong, I believe.
                                                #619135
                                                Tim Stevens
                                                  @timstevens64731
                                                  These double-ended screws are not 'differential screws' in the normal, english, meaning. For us, the meaning is wrong. This is not by any means the exception with products offered from elsewhere in the world. Try convincing our US cousins that a bolt is not the same as a screw – and they speak english … !
                                                  I suspect that some of the products we need do not have a specific name in some of the far-flung languages (just as the French have 94 different sauces and we have custard or gravy). But mainly the bloke that cobbles the adverts together has only a modest grasp of our language, and no access to relevant technical dictionaries, or the time to look stuff up. So, he looks for something similar and that will do.
                                                  Cheers, Tim
                                                  #619150
                                                  DC31k
                                                    @dc31k
                                                    Posted by Tim Stevens on 30/10/2022 15:58:23:
                                                    I know, isn't it terrible that Johnnie Foreigner cannot be bothered to learn our language. We won the war and all that jazz. And we had an Empire.
                                                    Unfortunately, your thesis falls flat on its face as the 'bloke that cobbles together the adverts' is the proprietor of this company:
                                                    Contact Us
                                                    Until your enlightenment, I was unaware that people in Dorset did not have English as a first language. I will certainly carry a phrase book next time I travel there.
                                                    #619151
                                                    old mart
                                                      @oldmart
                                                      It's not Dorset, but Darsett
