I use mine a lot but seldom screw them together so would not want to bin any of mine even if the holes were wonky. This week I have.
Used two 20-40-80 block stood to give me 100mm and then used my usual 10-20-40 block to set the height of various cutters and drill bits on the CNC relative to the 98mm ctr height of the rotary table, just enter +22mm off the 100mm stack rather than the usual 20mm off the top of the work.
Used two 1-2-3 blocks to pack a chuck that had 3 studs sticking out the back up off the mill table so it could be clamped down.
Used two 10-20-40 blocks to pack up some work that had a spigot sticking out the bottom, again so it could be clamped down to the mill table
Use two as paperweights to support a background for a photo
Used another to prop my phone up to video a bit of filing in the lathe.
And there is still Sunday to go.
