Soldering a front tube plate
Home Forums Locomotives Soldering a front tube plate
  • #567239
    John Billard 1
      @johnbillard1
      All the references I have seen advise that a front tube plate should be driven into the boiler shell before soldering. What about the capillary gap? Do we rely on the boiler shell expanding?
      John B
      John Billard 1
        @johnbillard1
        #567243
        Clive Brown 1
          @clivebrown1
          The shell expansion would presumaby be matched by the tube-plate expanding a similar amount. I haven't seen provision of a gap as an issue in boilers I've made. More like getting the tube-plate a reasonably close fit in the shell. If a capillary gap was seen to be needed then filing a very shallow taper around the tube-plate flange would suffice in my view.
          #567301
          John Billard 1
            @johnbillard1
            Thanks Clive. Presumably the tube plate is sealed by a fillet of solder. In any case I accept that if there was a gap it would be difficult to maintain it.
            Kind regards
            John B
            #567304
            noel shelley
              @noelshelley55608
              Not sure of the wisdom of a drive fit ? If heating is correct then the capilliary and surface tension will pull the tube plate into the centre and maintain an equal gap all round, all be it only may be 3 or 4 thou. The harder part is to hold the tube plate in place in the shell, there are many ways. If the soldering is sound there will be a very small fillet, the joint will be filled by solder and therefore steam tight. Good luck Noel.
              #567309
              Grindstone Cowboy
                @grindstonecowboy
                Never built a boiler myself, but have been following the Blondihacks Youtube series on making a vertical boiler. She made the tube plate a loose fit and used pins to hold it in place whilst soldering – for example here.
                Rob
                #567311
                nigel jones 5
                  @nigeljones5
                  Yes, maintain a slight interferance fit. There will be plenty of so called gap for the solder to penetrate the joint. Whatever you do dont try to manufacture a gap. How can I be sure of this? I make boilers for a living and have never had a joint faiulre – ever (having made hundreds of them). Anyone wanting to learn is very welcome to come visit me as Pendle Steam Boilers in sunny Burnley.
                  #567312
                  John Billard 1
                    @johnbillard1
                    Thanks Noel
                    You are quite right about a drive fit. What if it goes in awry and how do you retrieve it without damage?
                    Thanks Rob
                    The Blondihacks viewing is compulsory particularly as she is so honest about how it went wrong.
                    John B
                    #567362
                    John Billard 1
                      @johnbillard1
                      Thanks Fizzy, for sharing your experience. Thanks for the invitation! I am near Reading, but if I the the chance….
                      John B
                      #567373
                      nigel jones 5
                        @nigeljones5
                        No problem John. If you want any one to one advice feel free to contact me via my website **LINK**
                        #567397
                        John Billard 1
                          @johnbillard1
                          Thanks Fizzy
                          All going well so far, but you never know! Tubes soldered in to the firebox tube plate and firebox outer wrapper soldered to the barrel using 424 and 430.
                          Speedy Builder5
                            @speedybuilder5
                            Nice video Blondihacks. Question: What is the black flux she was using. I have seen White, pink, but never black.
                            Bob
                            #567406
                            Grindstone Cowboy
                              @grindstonecowboy
                              The flux is Stay-Silv Black by Harris Products apparently – I found their website here. Don't know if it's available in the UK though. She mentions it contains boron to extend the temperature range.
                              Links to https://www.harrisproductsgroup.com/en/Products/Alloys/Brazing/Fluxes/Stay-Silv-Black-Flux.aspx
                              Rob
                              #567410
                              nigel jones 5
                                @nigeljones5
                                The flux is available from the cup twins… I use it as a base and mix other fluxes with it to get the grade I like. It lasts a very long time and goes a very long way. Regarding the video – putting my neck on the tracks here but it is a video of how not to solder a boiler. Follow it at your perril – nuff said. Think Eutectic.
                                #567414
                                John Billard 1
                                  @johnbillard1
                                  Yes, this what I am using. Very impressive. As Fizzy says lasts a long time under the torch at high temp for the 424.
                                  Regarding Blondihacks yes plenty of errors there but she admits them.
                                  Cheers
                                  John B
                                  #567439
                                  Bill Phinn
                                    @billphinn90025
                                    Posted by fizzy on 19/10/2021 17:33:55:
                                    Please could you provide a link for the flux.
                                    #567443
                                    nigel jones 5
                                      @nigeljones5
                                      strangely its not on the cup website – but thats where i get mine from – I bulk order so dont go via the website
                                      #567462
                                      Luker
                                        @luker
                                        Hi Fizzy, I watched the second video of Blondihacks and I thought the end result came out ok. I'm a little curious as to what you mean by eutectic?
