Think about it. The lathe is very likely less than 500W.
How much of that available power is used by the lead screw drive?
Can you drill a hole without breaking a drill bit of that size?
Is that short pin, in shear more, or less, likely to break than a long drill bit, of similar size, waving around?
Do you have the skill to drill a small hole in these change wheels, at the appropriate position, bearing in mind that they all line up at the same distance from the centre line?
The answers to those questions may well lead you to the correct conclusion – as to whether the pin-drives are a cheap and practical drive option.
Edited By not done it yet on 16/05/2022 07:23:56
