hallo all
just new on the forum I would be pleased to take advantage of your experience, or yor specific knowledge, about commercially avaliable adjustable angle plates.
I was looking for one to mount on optimum bf20L, which should be the same as a Champion 20V or one of the most recents amavm25lv
examples are here link and here link, they are also avaliable from other suppliers bur essentially the same tools
The one I would prefer is the second one, I think it is more rigid and it would solve my setup.
I know the discussion about imported goods but I also believe is possible to make them accurate enough, with some effort, and for the price I think is worth it
the BF20 table size is 700x180mm with 3 slots 12mm wide and spaced 62mm.
I need to mount the angle plate with its T-slots perpendicular to the x axis (or its hinge should rotate along the y axis) to use it with my fourth axis rotary head , which is aligned to the x axis, since I have to mill some angled slots otherwise it would' t have been a problem.
the angle plate lower mounting slots should have a distance of about 124mm.
unfortunately from the description of the variuos angle plates this key information is missing and that is the distance of the mounting slots on the milling machine table.
they describe the dimensions of the top table of the plate and the spacing of the T slots but not the mounting side which goes on the table of the mill.
I would like to know if anyone owns one of those and which one of the avaliable adjustable angle plates might fit the dimensions of my mill's slots.
Of course I could make some adjustments in case of need but not major ones which might compromise the structure of the angle plate itself
I hope I was clear.
Thank you in advance for any help
Fabio
