Posted by David Maxwell 1 on 02/03/2022 13:18:57:.
..My Father was a very keen enthusiast of Model Engineer, I inherited a large pillar drill from him. I'd love to get it working again.
He purchased the single phase equipment in the 1950's …
It last worked in the 1970's but has not been connected since. I'm nervous of the capacitor! …
What is it? Is it a just a start capacitor or does it assist with the running? No visible markings on the capacitor. All ideas for a replacement welcome.
I can send photos but have no idea how to add photos at this stage…
Welcome to the forum David.
Last things first, how to post photos is easy enough when you know how! Click on this link for instructions. Another forum peculiarity, the obvious 'Search this site' feature top right of screen doesn't work well. There's a much better search facility half-way down the Home page.
Depending on the exact type, single phase motors have either one or two capacitors. One is used to start the motor, the other to keep it running. (Done by delaying the magnetic field in the motor windings relative to each other which creates a turning force.) Sometimes one capacitor, sometimes two, and sometimes two capacitors are in one container (three or four wires to it). Posting a photo will help identify the motor, especially if it has a info plate.
I agree with trying the motor to see if it works before fixing it. However, proceed with caution in case old-age and damp have left the machine electrically unsafe. Damp and corrosion play havoc with insulation and rubber insulation perishes, cracks, and falls off! Before applying power, use a multimeter to confirm the earth pin and all exposed metal parts of the machine are connected. (Correct earthing protects against several shock hazards.)
When powering up, don't touch the machine until certain it's electrically safe. Use an electricians screwdriver to confirm the metalwork isn't live. Blowing fuses, popping RCDs and smoke are all obviously bad! Also bad, if gently stroking the machine with a finger tip causes a tingle or odd rubbing odd sensation.
As general advice, I don't recommend rushing to strip and fix old machines. Better to start with a shallow clean and then to run the machine, gently putting the controls through their paces. Experimental running is an excellent way of highlighting faults, many of which are heard rather than seen. List as many as possible before attempting repairs and have a think, especially if inexperienced. The problem with starting with a gung-ho strip, deep clean and random mending is it risks introducing hard to diagnose new faults. A mixture or wear and tear and assembly errors can be a right pig to sort out.
Don't panic though! Assuming reasonable storage and a dash of luck, the drill will run without problems. If not, ask again.
