Delapena External Hones
Home Forums Workshop Tools and Tooling Delapena External Hones
  • #586414
    IanH
      @ianh
      Hi,
      I recently acquired a pair of Delapena external hones, one small and one large. Some of the stones are in poor shape and I would like to sort them out.
      I understand that these tools are no longer made so I am looking for replacement abrasive stones assuming I can remove the existing stones from the holders and glue in replacements.
      The stones are numbered 11 to 15-P8-F for the bigger tool and 3 to 6-P8-F for the smaller one. Looking at the Delapena Web site I think F denotes silicon carbide but I can't see anything to decode grit size.
      The hones will be used on decent steels, En16, EN24 and case hardened EN36B for example.
      The bigger stones are 2" long 3/16" wide and 1/8" thick, the smaller ones are 3/4" long by 0.1" Square.
      The existing holders could be modified to suit stones of a different section assuming I can cut the replacement stones to length somehow.
      I have emailed Delapena to see if they have any info or suitable stones, but I thought I would ask the forum at the same time as someone is bound to have done this already or will have some good ideas.
      Thanks,
      Ian
      IanH
        @ianh
        Stone replacement
        #586418
        John P
          @johnp77052
          Have a look on Ali*****ss probably thousands of choices grits up to 3200# for these type of stones can't give any reference numbers on here as they will be taken down almost instantly.
          David George 1
            @davidgeorge1
            Try these
            https://www.kemet.co.uk/products/toolroom/gesswein-abrasive-stones
            I use them not cheap but ask them and they will suggest the corect style and grade etc
            David
            #586436
            Adrian Nicolson
              @adriannicolson
              Hi IanH,
              If I can recall all this correctly…but please bear in mind that I am trying to remember detail from decades ago, when I was still in the Toolroom. Grit Sizes on the smaller stones/hones were available from 60 to 500grit and the Delapena Codes for these smaller stones was split/defined as follows:
              Delapena code 0 = 60 grit, 1 = 80 grit, 2 = 120 grit, 3 = 180 grit, 4 =220 grit, 6 = 320 grit & 8 = 500 grit
              You are correct in that F = Silicon Carbide…
              The other common abrasives, readily available were: R = Aluminium Oxide (Soft Steels up to HRC 50), C = Bauxilite, which was cool cutting and for Hardened Steels over HRC 50)…I also seem to recall that they used to supply another couple of variants of "speciality stones", for special finishes…but I can't recall what they were…
              Thinking back…I think? the other letter in the Code relates to the Bond Hardness. Hard Materials needed a Soft Grade…and Vice-Versa…
              Sorry that I can't give you more information…but I am sure that someone out there must have some old "bumf" lying around…Hopefully they will step in…and clarify any holes…
              Best Regards,
              Adrian
              #586669
              JohnF
                @johnf59703
                Ian please see your messages,
                The original method of fixing the stones to the carriers was a powder adhesive you applied to the mount then heated it on a hot plate [i use an old flat iron upturned] the worn stones can be removed with heat. I guess now its possible to use an epoxy,
