Hi Noel – Thanks for your reply, I have heard that as well. I have DRO on the mill otherwise it would be well beyond my experience / ability to tackle. I think the basics must be correct because they go like the clappers on air, very frustrating they don't run on steam.
Hi Jon – Thanks for getting back to me. I fixed the shuttle valves at an early stage in the make, but you are right it is a key source of problems if you are not very careful. As for the clacks I did not follow the drawings, they looked very fiddly and rather delicate? I made ordinary type in line clacks with a Nitrile ball (its a cold water feed so Nitrile is OK). By ordinary I mean the type that have a deep groove in one face and the ball is pressed against it in the on position allowing the water to flow around it, through the groove and out. In the off positing the ball presses against a seating to stop water flow. They seem to work well and I have had no problems (yet!) with transient back flow – might be worth a try? However without a spring and with no pressure to close them they do let water through, but as they connect the water tank to the pump and then a boiler clack the whole feed water line can remain flooded. Hope that all makes some kind of sense?
Martin
