What to use
What to use
Home Forums Workshop Tools and Tooling What to use
  • #575152
    Dell
      @dell
      I have stripped and cleaned my Pultra crosslide but what to lubricate it with because it seems to have had both in the past.
      Thanks in advance Dell
      Dell
        @dell
        #575156
        Nigel Graham 2
          @nigelgraham2
          Any "slideway oil" (simple single-grade, fairly thin mineral-oil about SAE 50) should be fine. My machine-tools seem happy enough with what is labelled as "Hydraulic Oil".
          You don't say what are the "both" but grease is not advised.
          Do you have a manual for the machine? That should tell you. You may be able to obtain one, perhaps a photocopy from lathes.co
          #575162
          Dell
            @dell
            Thanks Nigel
            yes it was grease , I have a manual from Tony but all in said was oil the screws nothing else.
            Dell
