Just as an introduction before my question – I have recently started making portfolio boxes for artists. I use greyboard for the structure then cover in book cloth. For cutting greyboard, I was using a steel ruler and olfa knife but find it not precise enough. The two options for greyboard cutting are Victorian board cutters or a heavy duty guillotine. The first is hard to acquire, and both are large and expensive.
I came across the Proxxon FET table saw, and contacted suppliers and manufacturers who told me it would be suitable with the right blade for cutting greyboard.
My main questions are regarding safety and additional accessories I may need.
– Is it essential to get a sled for smaller work? Some pieces I will cut will be to 3cm height and 10cm long.
– The material is about 3mm thick, and when laying flat to cut, I will require the blade to be 45 degrees to achieve bevelled edges. In this case, I take it a small sled wouldn't be possible?
– I have watched some videos about saw safety, but is there any advice for cutting a thin lighter material? I plan to cut down from a3 sheet size of possible, then cut the smaller pieces I need.
Any suggestions of accessories welcome also.
Thanks, Rob
