The micrometers are Drum types. The large diameter barrel allows the graduations to be wide apart, so that they can be subdivided, probably into tenths of a thou instead of thous on an normal micrometer barrel.
Possibly, they came from Height Micrometers.
The Budenberg tester is used to calibrate pressure gauges.
The various pressures are obtained by loading a disc of known specific weight onto the plunger with the gauge to be calibrated fitted to the connection. The pump is then used to increase the pressure, until the weight just "floats"
This allows the gauge reading to be compared with what it should be, and corrected if need be..
This procedure is repeated for each increment of the gauge graduations; probably in 10 psi steps.
It is very good piece of kit, if all the weights are there. There should be at least ten, to cover from 10 psi upto 100 psi.
The electrical device, Pye Scientific Instruments is used to check Thermocouples, to measure their ouput, and again, to calibrate a electronic temperature measuring set up (Thermocouple connected to a sensitive moving coil meter, measuring milliVolts, but probably graduated in degrees C. )
All this stuff, including the Toolmakers cabinet should be quite valuable. Most of it would have come from a Standards Room, or Cakibration Room, and would have been very carefully looked after..
The kind of kit that one would be a joy to own, but have no actual immediate use for it! (On a shelf, I have two drum micrometers for which I have yet to find a use )
Howard Fat fingers strike again!
Edited By Howard Lewis on 10/09/2021 19:14:55
