me august 1961
me august 1961
Home Forums Locomotives me august 1961
  • #544639
    Peter Townsend 2
      @petertownsend2
      hi am looking for page 716 in the august 1961 model engineer that gives the assembly of the cab reversing gear any help would be appreciated thanks
      Peter Townsend 2
        @petertownsend2
        cab reversing gear
        #544651
        Meunier
          @meunier
          According to my records, august 1961, 4issues, contained only 100 and 200-series page numbers, not 716.
          Can you clarify ? which loco ?
          DaveD
          #544654
          Ady1
            @ady1
            Your page numbers are way out and no index in those 4 issues has "cab reversing gear"
            #544691
            Peter Townsend 2
              @petertownsend2
              hi i have the 3 august 1961 copy vol 125 no3134 and am working from page 151 rob roy by martin evans valve gear and reversing lever drawing on pg 152 and details on 153 at the end of chapter he says it is assembled on page 716 yhanks
              #544693
              Jon Lawes
                @jonlawes51698
                I thought you were working on a Springbok? You need to find a copy of the Martin Evans book that covers the Rob Roy and William locomotives; its got almost everything in there.
                #544697
                  Posted by Peter Townsend 2 on 13/05/2021 03:27:28:
                  I would guess that ^^^ should read page 176 [being in the next issue]
                  It’s not my area of interest though; so this might only add to the confusion!
                  Grabbed from an advert:
                  #544708
                    More like 178 if its by Martin Evans, Peter PM me an e-mail address. Ady1 has put them up so no ned to email
                    Edited By JasonB on 13/05/2021 07:48:56
                    #544710
                    Ady1
                      @ady1
                      Nothing on 176 either
                      There's some firefly build stuff from page 178
                      I have put those pages in here in case they help
                      #544714
                      Nicholas Farr
                        @nicholasfarr14254
                        Hi, in an index I have, the next instalment for Rob Roy after 3134 is in 3138, page 264, in which is, setting of the valves, fitting of steam and exhaust pipes. Super heater connections, easy removal, suction pipe union.
                        The only mention I've found of a page 716, is in vol 125, 3132, page 89, which is about an error on drawing on page 716, vol 124.
                        Regards Nick.
                        #544724
                        Robin King
                          @robinking15611
                          Peter,
                          The page you are looking for is page 716, 8th June 1961 which gives the g.a. drawing of the Rob Roy valve gear plus reversing lever.
                          #544726
                            Posted by Robin King on 13/05/2021 09:20:53:
                            Peter,
                            Aha !! … The old ‘change the volume numbering a some odd time of year’ trick
                              Pg 716, click for larger image.
