Posted by martin haysom on 08/06/2021 12:59:34:
all my air tools say they need 4cuft/min yet my compressor a laycock lx which should be 10cuft/min can't keep up with them
Martin,
The only ‘close’ info I could find on the net was this (it may not be your machine) is reproduced here:
“LAVCOCK ENGINEERING LTD. Archer Road, Millhouses, Sheffield 8 TN Laycock's single-stage range and suitable for tyre inflation is the LX/2 portable compressor, mounted on a tabular frame with 7.5 in. rubber-tyred wheels. Its 2.5 Cu. ft. unit gives an air delivery of 1.1 c.f.m.
The LX/3 vertical compressor is fully automatic with a pressure switch cutting out at 150 p.s.i. and cutting in at 125 p.s.i. A directcoupled 5 h.p. electric motor drives the 2.5 cu. ft. unit which has a large after-cooler and condensate trap.
Four models arc listed in the vertical range, LX/5V having a displacement of 5 c.f.m. and a working pressure of 150 p.s.i. The other three models, LX/9V, LX/15V and LX/20V have working pressures of 200 p.s.i. Displacement in c.f.m. is denoted by the model number.
In the horizontal range, six models are available prefixed by LX 5, 10, 15, 20, 35, 42, the numbers denoting the displacement in c.f.m.”
If this is the range, what number is the suffix on yours?
