It depends what you mean by inaccurate. If you convert the imperial gauge block dimensions to metric, noting that if made in the last 50 years they will be on the basis that 1 inch = 25.4 mm exactly, then you just need to work out the stack of imp blocks you need to get the required metric height for the desired angle. Or, in reverse, work on the basis that 125 mm = 4.922 inches.
Going the first route, for an angle A degrees, the height required is 125 x sin(A) mm, so divide that by 25.4 to get required inch stack; or just use the formula h = 4.922 sin(A) inches. A scientific calculator helps, there will be one on your phone or if not there will be an app you can download.
But just how accurate do you need the angle? A simple and cheap Wixey angle measuring box will resolve 0.1 degrees and they are pretty accurate according to my measurements, and probably cheaper than a sine bar.
Edited By John Haine on 05/06/2021 09:03:53
