+1 for checking that the self eject is not causing your problem. As advised, wind the Tailstock barrel out some way (At least 50 mm ) and check that the 2 MT arbor then grips in the CLEAN taper bore..
If it does, winding the barrel back in should eject the arbor. Problem solved! Note for future reference.
All part of getting to know your machine. Does the operator manual not tell you this?
If it is the chuck spinning on the Arbor, it may be that the taper for the chuck, on the arbor is not the same as that in the drill chuck
Try checking the B16 taper against the drill chuck, with blue. If you don't have any blue, coat the tape, all over, with a felt tip pen and then rotate the arbor in the drill chuck. If the internal and external tapers differ, there will only be a bright ring where the two tapers have made contact. If the blue is removed completely, the tapers match. All that is then needed is to make sure that both tapers are clean, before pushing the arbor into the drill chuck. Retract the chuck jaws into the chuck body, hold the assembly by the 2MT and bang it hard on a piece of wood on the bench.
Find a local Model Engineering Society and join. You can ask all manner of questions face to face, and probably get one to one advice in person.
Edited By Howard Lewis on 05/05/2021 20:15:38
