It looks like a ML3 or 4.
A Ml1 or 2 would have a centre height of m3.125" where the 3 and 4 are 3.5"
The ML3 is 15" centre distance, where the 4 is 24" (Confirm with Lathes UK website )
Yours appears to have the optional Tumbler Reverse and the side hinged cover for the Changewheels.
The Leadscrew is 8 tpi, but the Leadscrews for the Cross and Topslide are 12 tpi. The dials for these have 80 divisions, which means that each division is not 0.001" but 0.00104"
Chagewheels are driven by driving collars (secured to the Mandrel and Leadscrew by 1/4 BSF grub or capscrews.
(Virtrually all threads, except possibly the gib adjusters, will be BSW or BSF )
To transfer the drive between the collars and gears, or to compound gears, there is a 3/32" pin in a blind hole in each part.
If you are short of Changewjheels, those from the 7 Series will fit. Dimensionally they are the same, but have a keyway instead of the 3/32 hole.
So you will need to drill through one original gear to use as a template. Fit both gears onto one of the changewheel studs, and drill though into the 7 Series gear, keeping away from the keyway..
With additional gears, you can set up a fine feed, 20:60/20:65/20:60. This will give a fine feed for turning of 0.0000427" / rev. You may need to fettle the inside of the Mandrel end of the Banjo to enable the first stud to move far enough to set the correct mesh for the gears.
My advice is to set the mesh, starting from the Leadscxrew, and working your way to the Mandrel. Just run a piece of paper about 0.003" thick between the gears.
HTH
