Yes – I can vouch for most of those already named, as ones I have used. Most of my insert-tooling is from JB.
Also…
Tony Griffiths' excellent Lathes.co site, for information, manuals and accessories, and its second-hand ads section .
ToolStation – possibly more useful for engineering than is Screwfix, but I have used both. Among other things, TS stocks limited ranges of bandsaw blades, arc-welding rods and MIG wire, quite a wide range of metric fastenings and PPE.
Modelfixings is aimed particularly at our model boats and planes brethren, but is very good for small-diameter, mainly but not only metric, fasteners and many other items for physically-small work.
Bearings R Us – transmission products.
Newton-Tesla has sold me no less than four 3ph-motor and VFD drive sets. (For my Myford 7, Harrison L5, Myford VMC mill and BCA jig-borer) –
– while the mill also sports an Allendale's (Machine-DRO) 3-axis DRO set.
Locally, Townsend Bearings, in Bridport (W. Dorset) stocks or are agents for a wide range of engineering items and consumables, but unfortunately the shop catalogue on its web-site seems have been broken for quite a while. It also offers a shot-blasting and plastic-coating services to private and trade customers.
Not far from Townsend's, is Bridport Foundry, who now produce the Stuart castings.
Cutwel – cutting-tools. I thought when I first found their name that this is a trade-only firm (as RS used to be), and indeed most of its range is for modern industrial, CNC-led manufacturing; but I have seen it recommended by other users on this forum.
It's also interesting to see what's available for at least workshop even if not necessarily model materials, from retailers outside of the obvious.
E.g. building hardware (studding, brackets various, etc.) .
The flexible "conduit " adding protection to my mill's DRO signal cables are lengths of caravan sink waste-hose from a camp-site shop (normal service temporarily suspended): I needed that diameter, about 32mm, to thread the sensors through. The saddle-clips made for that tube hold it to the machine. I think the same shop also sells medium-diameter copper tube and fittings, for caravan gas-fitting, but potentially useful for larger-scale steam models; plus a fair range of awning-pole and other materials that with a little imagination…
