Hello William,
MOK. Where to start!
For the SR L1 (inside cylinders version) you have a choice of Joy valve gear or Stephensons valve gear.
The Joy valve gear version is regarded as very good, but not prototypical.
The Stephensons gear as designed by LBSC in the late 1940s is awful.
Hence, K N Harris, and later Don Young redid it. The K N Harris version is more of a complete rebuild, and has a peculiarity from memory.
The Don Young version is less radical and I would suggest be considered. See ME 7th and 21st November 1969.
The Don Young version could do with amending in some minor details as there is no suspension offset, and the lifting arm length may be wrong on the weighshaft, and I am far from convinced that the rocker arm bearing is in the optimum position.
As for Joy gear being not to prototype, there are lots of things about MOK that are not accurate, and to start with it doesn't have piston valves, so personally I wouldn't be too bothered about this.
The driving wheels are BIG!
Cheers,
Julian
